looking for better turbo Mani
Old Sep 7, 2008 | 09:04 AM
  #21
passmans2kny's Avatar
just because moving air through the engine bay is a good thing it doesnt mean getting it out through any means(vented hood) is bad, u want as much air as possible and venting the hood lets the hot air escape while newer colder air from the front goes in
Old Sep 7, 2008 | 12:23 PM
  #22
s2guru's Avatar
I will be buying a mugen hood to help the heat.
I will re-wire fusebox/Eps to fenders and try to relocate the brake line. If that does not help i will get a full-race manifold.
Thank you guys for all the help.
passmans2kny: how much wire was used to re-wire the fusebox/eps and what type and size of wire did you used?
Old Sep 7, 2008 | 01:38 PM
  #23
Spec_Ops2087's Avatar
Originally Posted by kutsujula,Sep 7 2008, 11:03 AM
how could venting the hood be bad? your getting all the heat out of the engine bay and lowering IATs?
Although I don't believe the s2000 suffers from this, I'm sure there are cars that would suffer from a vented hood. Venting the hood completely changes the way air flows in the engine bay which in some cases could actually hamper performance.
Old Sep 7, 2008 | 03:52 PM
  #24
GDM S2K's Avatar
GT1 I removed the body harness where hthe manifold runs, put the battery in trunk and used a fosgate distribution block under the fuse box, flipped the box around pushed it back toward the fire wall and fender, also did a lil somethin with my vac lines on the intake-
Old Sep 7, 2008 | 03:56 PM
  #25
i bought 24 feet of power cord from a hardware store, and im not running eps, i gotta get a camera bad
Old Sep 7, 2008 | 08:42 PM
  #26
Honda_Mad's Avatar
Old Sep 8, 2008 | 02:37 AM
  #27
s2guru's Avatar
Yes you do, i want to see pic of your set up. =)
Old Sep 11, 2008 | 02:25 PM
  #28
Full Race Geoff's Avatar
thanks for the compliments guys. the full-race s2000 manifold will perform very well, and i definitely recommend it over a "sidewinder" design, particularly for this chassis. We have prototyped some sidewinder designs, and none of them hold a candle to our prostreet manifold design, whether its in peak power/tq or boost control.
its very important to combat heat in the engine bay - one fantastic method that is also very easy to do, is to use our Gold Foil (heat reflective). this can drop temperatures 800 degrees F in only 3mm. By wrapping brake lines, wiring, fuse boxes, AC lines, really ANYTHING that can melt or be damaged by the heat can easily be covered with our self-adhesive gold foil and prevent a lot of problems/damage. All of our turbokits come with this foil free of charge. for manifold orders, its a good idea to also order some
edit s2guru -- did you really make her lick your turbo?!?! haha thats a funny avatar, it looks like she doesnt like the taste of cast aluminum too much...
Old Sep 11, 2008 | 02:53 PM
  #29
Terror's Avatar
If you are worried about heat, I've heard Swaintech's White Lightning coating does a great job.
Combined with the Heat Reflective foil, I'm sure this would solve any under hood temperature problem.
Old Sep 11, 2008 | 07:49 PM
  #30
spdracerut's Avatar
With regards to a vented hood... I would think that adding a vent above the location of the turbo would help.
Or go with the reverse idea, and get a NACA duct to bring cooling air to that area, similar to the duct on the Evo X.
