Looking for part
Hello all,
I am looking for a part for my car and need to find a name/part number. I THINK it is some kind of oil pressure sensor. It is on the front part of the engine, just below cam cover on the passenger side. I cracked it installing my SC and while I can hold the harness on with a piece of tape, the clip on the wiring harness is broken as is the plastic on the sensor. The two metal tabs from the sensor still slide into the two metal clips, but I would like to get the new sensor at a minimum and a new plastic clip/assembly on the wiring harness end if that is possible.
Does anyone know of a site where I can look at a diagram that lists all the different sensor part numbers? I had one but can not find it anymore.
Thanks,
John
Thanks,
John
It is in the far right of the picture, bad pic but the only one I have at work. Just above the oil filter, the grey clip shows where I snapped it the first time, this is the second time I have done this. It is in a bad location for mounting SOT kits, and I did not learn my lesson the first time.
An old thread has this listed as oil pressure sender, but I have no part number if anyone has a link to a diagram with part numbers. There used to be a few sites on the web to find the diagram for sensors, I can't seem to find one anymore.
Is it #16 in this diagram?
37250-PCX-A02 - SWITCH ASSY., VALVE TIMING OILPRESSURE
http://www.hondaautomotiveparts.com/...=CYLINDER+HEAD
Thanks Coolguy, that helped.
Camuman, no AEM but most likely Haltech coming soon. Still have a foot of snow on the ground and no new pulley yet. Guessing I will have numbers in June for the new blower. Work schedule does not allow before then.
