Looking for recommendations on a Turbo
Hi all,
I'm running a full race twinscroll divided t4 front facing manifold on a f22, and was wondering what the fastest spooling/most transient turbo for 550-600 hp these days is. I was thinking about a BW 7163 EFR w/.8 AR but not sure if I should consider a different route.
Appreciate your help and advice.
Hi all,
I Tried a .83 housing and a 1.0 housing. both twinscroll. The .83 is too small, it will choke up at higher boost levels, but would make boost leaving a stop light..was nuts. Was able to achieve 594hp with a 1.0 housing and it still had great spool time
Very interesting I just did a forum search (where I saw you post) about the 257sxe and how it made mid 400's on 12lbs of boost. That's very impressive. I was actually leaning on the 1.06AR Gen II GTX3076r but the price difference between the two is jarring (nearly double for the 76r). Now that you mention that the dyno graphs were nearly identical I can't stop but wonder if it's worth it. Was it a fluke? The 76r should have a more transient response than the 257 but their spool and power outputs are the same? Wonder what you guys think.
Wadsworth is using the 550 on his track car, he said it worked amazingly. I heard that T4 housings came out recently. Not sure if its aftermarket or not, I have yet to see them though.
The GTX3076R is a mediocre turbo due to mismatch in wheel sizing. This leads to a poor blade speed ratio and therefore poor turbine efficiency, so the spool sucks. Either go GTX3071R, or GTX3576R which spools the same as the 3076 but makes 50whp more on race gas. If you want super crazy spool, G25-550 in the 0.72. G25-660 for a bit more power. The G25-660 is a bit mismatched, but jumping to a G30-660 forces you into a 0.83 A/R which will slow up spool a bit. Though the G30-660 in the 0.83 should spool better than the GTX3071R in a 0.82/0.83 and make the same power. Or step it up a bit more to the G30-770. I wouldn't use the 0.92 A/R (G25) or 1.01 A/R (G30) on anything except big V8s using a pair. I don't think the G-series is available in twin-scroll yet.
Thanks you everyone for your input!
