Losing Boost on CTSC
Old Jan 26, 2006 | 12:38 PM
j_c_a's Avatar
Default Losing Boost on CTSC
A couple days ago, for no reason that i can tell, my CTSC started losing boost. Everything seems fine until about 7K, then my boost just levels off. There's a noticable loss of acceleration as well.
I've checked my belt and it's plenty tight. The only thing I can think of is my bov could be leaking. Anybody have any thoughts?
Old Jan 26, 2006 | 01:15 PM
Asura's Avatar
Check your vacuum lines.
Old Jan 26, 2006 | 01:21 PM
phillys2k's Avatar
check ur ic pipings u might have leak there
Old Jan 26, 2006 | 01:38 PM
SIIK2NR's Avatar
1. Check your transition hose from the the throttle body to the Aftercooler (if you have one)
2. Check your transition hose from the blower to the aftercooler (if you have one)
3. Check your air filter. You'd be surprised....give a good cleaning you you will feel the difference!!
Old Jan 27, 2006 | 12:17 AM
Trip's Avatar
I have the same problem too.. but lately i am logging late at night which might be humidity issues.
I run on a 7psi pulley
Old Jan 27, 2006 | 05:02 AM
j_c_a's Avatar
I don't think mine has anything to do w/ humity. I was doing a few pulls late at night to fine tune my a/f a bit, and it started doing this between one pull and the next.
So last night:
I inspected all my major transiations; replaced a suspect clamp.
Inspected all vacume lines; replaced the check valve.
Removed and inspected the BOV; relubed all o-rings and reinstalled.
Still having the same issue. The BOV seems to be working fine, but it's still my primary suspect b/c i can't think of any other areas I could be losing boost from. Tonight I will remove it and replace w/ the stock ct "bov" and see it that could be the issue. I can't hear the BOV releasing air when my boost levels off, but my exhaust is very loud at that point so it's possible
If it's not the BOV, I have no idea what it could be.
Old Jan 28, 2006 | 10:19 AM
j_c_a's Avatar
In case anyone runs into the same problem, i figured out what this was. I had a bad MAP sensor. I was reading boost from the MAP so it looked like a boost leak, and b/c of the effect of the ecm, it felt like a boost leak.
Replaced the MAP and boost is reading like it should, but will need to redo my tune.
Old Jan 28, 2006 | 11:45 AM
Trip's Avatar
This afternoon the weather was perfect and logged my boost again.
Here is the comparison. It looks like Humidity during night runs does lower the boost up top but strangly enough it is higher in the lower/midrange rpm
Old Jan 28, 2006 | 11:56 AM
j_c_a's Avatar
Interesting. Once i get my tune dialed back in, maybe i'll do some night/day comparisons. It's pretty humid here in FL so it would interesting to see if i have the same behavior you're seeing.
vanDiemen
May 2, 2015 06:56 AM
branden2k
Nov 5, 2013 06:49 PM
landonplumbtree
Feb 19, 2011 09:57 AM
cbrguy7
Sep 2, 2007 01:24 PM
bgbfflochp
Jun 13, 2004 03:04 PM
