Losing coolant Head gasket?
Old Jan 28, 2011 | 03:49 PM
  #21
Competitor9's Avatar
Originally Posted by Competitor9,Jan 26 2011, 04:25 PM
Can a blown head gasket spray coolant from the block?
Short of that lets pretend we never met I know I'd like nothing more
Only question ^^^
Do you have an answer
Old Jan 29, 2011 | 05:22 AM
  #22
teamvalorracing's Avatar
*sigh
well, a blown head gasket is in-between the block and head. so if you have coolant spraying out of your BLOCK, then it has nothing to do with the HG.
if, however, you have coolant spraying out between the head and the block, then yes, it is a possibility as the hg seals coolant passages off from the exterior of the motor as well as from the combustion chambers.
but that would be extremely unlikely as you would need to warp the head very precisely to not effect the cyls, but rather the coolant passages on the outer edges of the head(which would remain the coolest portion of the assembly).
if you have coolant leaking from the block somewhere(below the head), it may by the water pump thats leaking the fluid, or a split hose. other than that, check other areas first as recommended previously in the thread.
braeden
Jul 18, 2015 12:54 AM
AP1GroceryGetter
Nov 15, 2013 03:15 PM
ajv85483
Mar 2, 2010 10:20 AM
J.nguyen
Jul 12, 2008 08:00 PM
Squeezer
Feb 11, 2003 06:11 PM
