LoveFab in 2.2?
Originally Posted by kane.s2k,Jul 28 2005, 08:26 AM
and it'll spool up faster. Who doesn't want that?
more displacement means more air/energy is pushed through the turbo at a lower RPM, which means itll spool up sooner.
And yes, the 2.5 stroker would be sick if you could lower the compression enough. Just dont rev the piss out of it, otherwise youll see some fire and chunks underneath you(Best Motoring video, J's car). Although, I think he mechanically over-revved, but point being, there is no replacement for displacement
Sure, you can turn up the boost, but if you want torque sooner, go larger displacement.
The lack of piston oil squirters on the IP 2.5 has me concerned enough on a NA car, never mind a turbo'd 2.5 that has even more heat to deal with.
BTW, a stock F20C has the oil squirters for piston cooling.
The Super Street cover car doesn't have a 2.5L. The entire article is pretty much BS from start to finish.
