low boost? high boost?
Old Jan 31, 2011 | 05:52 PM
siadam's Avatar
Your better off to learn what you need and piece it together, "kits" are typically way overpriced.
Old Jan 31, 2011 | 05:58 PM
2003blacks2k's Avatar
Ok I'll look into that and see how much I can peace basically the kit I want for but in part form if that makes sence
Old Jan 31, 2011 | 06:22 PM
DFWs2k's Avatar
Skip the fuel rail, waste of $ for what you are doing
Old Jan 31, 2011 | 06:44 PM
I might up more hp later.
Old Jan 31, 2011 | 09:14 PM
3en's Avatar
3en
Keep your eyes on the classifieds. You can find good deal on used kits. Fr kits don't come up very often. Mase and pfab seem to be the ones that come up the most that I would recommend. Inline pros street kit would put you in that range also. You'll need the following parts-
Turbo
Manifold
Dumptubes
Downpipe
Wastegate
Bov
Ems
Intercooler
Ic piping
Couplers
Tbolt clamps
Oil feed line
Oil drain line
Water lines
Map sensor
1000cc injectors
Clutch
Fittings
Ems
Wideband
Boost gauge
Optional
Exhaust
Wider tires
Oil pressure gauge
Reinforced diff
Catch can
Oil relocation kit
Ac relocation kit
Battery relocation
2/3 mm headgasket - debatable
You also might want to think about upgrading you valve spring retainers to ap2 retainers.
I think I named everything you'll need
Good luck!
Old Jan 31, 2011 | 09:40 PM
Thank you good sir that's alot of help I'll print that out write it on paper and see how much it all cost. instead of a full kit. I'll see what ones cheaper I also looked into inline a little bit. wasent sure how reliable the kit was. I hear Garrett is really realiable. Compared to most turbos out there. I don't know much about the other kits Ive really only focus so far on full race due to the nice spool of the gt3076r and 71. and the nice high end of them more the 76 of course. It's like the perfect balance. ive looked at rev hard and greddy basically a joke from what I read unless your looking for a huge realiable dd car and to stay in state laws. I've read a little on precision turbos. I've heard of mase and full blown but haven't looked into them at all.
Old Jan 31, 2011 | 09:41 PM
Deception's Avatar
^^ add updated oil squirters to the list for earlier AP1 motors, his 03 may or may not need them depending on VIN#
Old Jan 31, 2011 | 10:03 PM
I don't know about that one I'd have to check. something to ask my friend he knows why more about that stuff then I do
Old Jan 31, 2011 | 11:11 PM
vietdragontekx's Avatar
I have the full race kit with the 750 RC injectors, the injector is pretty much max out. I'm pushing 420whp at 14psi. would definitely go with the ID 1000 CC.
Old Jan 31, 2011 | 11:18 PM
ya might as well I've seen 650 for 325 and for 100 bucks more i could have 1000 cc that can be tuned to do low boost and high id much rather go with the 1000. honestly guys thanks for the help its very much appreciated. =]
flyingflyflyer
Jun 21, 2013 03:36 AM
killabee
Mar 25, 2010 07:23 PM
sbrodacz
Sep 12, 2008 06:58 PM
Aznpridedan20
Oct 22, 2004 02:56 PM
