major boost creep
. The best bet for solving this issue is a bigger gate. Also like mentioned before timing could be too retarded. What they sent you is probably a "Safe" map with low timing so you can get the car up and running before getting tuned. Unfortunately on setups with undersized gates this often leads to excessive creep in high rpms.
Hello guys,
anybody that has any questions or issues with our manifolds/turbo kit. Please call me at 321-235-2699 or email bebo@kingsperformance.com
I will be more than happy to help, fix & answer everybody questions.
Thanks for your time & look forward helping everybody out,
Fernando @ Kings Performance
i have spoken to one of you tuners a couple of times and he said he doesn't know what is causing the problem he said it should creep with the setup i have and that he hasent had this problem before but mine does so the best thing is to add another wastegate
MadSp33d
May 3, 2003 06:36 PM
fingers crossed once this is done should hold boost ill keep you guy posted thanks for your help
