Manifold bolts sheered off
I had the exact same circumstances with one of the allen screws on the plug cover a few years ago. What i eventually did was take a cold chisel and.cut a notch into the head of the bolt. I locked some vice grips around a huge flathead screwdrive and turned that bitch out :thumpup: . Do you have of that stud protruding out of the head so you would be able to do the same?
Ahh man that sucks....little trick we do is carefully weld another bolt to the broken one and then take it out. Not exactly sure how much room you have to work with but yea.
I never use extractor bit just because of what happened. Good luck!
Get a mig or tig welder and weld a nugget of steel onto the top of the broken off piece. The heat will help loosen it. You should be able to grab it with some side cutters. If its really stuck weld through the centre of a nut onto the broken off bit, an once its cooled a bit use a spanner to remove.
I never had much success with ease outs and use the welding technique as first resort.
This technique even works well on broken off taps.
Unfortunately, I don't have access to a welder (don't have the skills either!)
Pulling the head is the last resort...but if it does come to that, I have a fully built Alaniz head sitting in my garage
Scott-
