Map sensor for EMS
Old Nov 17, 2008 | 08:52 PM
518135's Avatar
Default Map sensor for EMS
I just picked up a AEM EMS and will be purchasing an Inline pro turbo kit. I was wondering if I have to get one of the map sensor kits for it? I plan on running high boost.
Old Nov 17, 2008 | 09:09 PM
9kFever's Avatar
Hondata is plug and play. Fits right in OEM location
Old Nov 17, 2008 | 09:10 PM
AusS2000's Avatar
If you plan on running over 12psi you will need an aftermarket MAP sensor.
The AEM ems has built in wizards for the AEM and GM MAP sensors.
But you can still use the Omnipower and Hondata MAP sensors with a bit of setup.
Old Nov 17, 2008 | 09:13 PM
TelosHedge's Avatar
Originally Posted by AusS2000,Nov 18 2008, 02:10 AM
...you can still use the Omnipower and Hondata MAP sensors with a bit of setup.
shouldn't be too hard right? if it's anything like the kpro it's just some voltage settings right?
Old Nov 17, 2008 | 09:15 PM
AusS2000's Avatar
Yup, just a table or voltage to load (pressure). There are values for the Omnipower on a thread somewhere.
Old Nov 18, 2008 | 08:41 AM
518135's Avatar
Thanks guys. I will check into it.
Old Nov 18, 2008 | 01:52 PM
08s2000CRbackinblack's Avatar
im getting kpro soon. so from what ur saying i wont need an aftermarket map sensor until i run over 12 psi?
F1TwoThousand
Oct 15, 2018 08:54 AM
blink962
Oct 10, 2016 08:04 AM
vietdragontekx
Dec 7, 2010 12:25 AM
ChefJ
Apr 24, 2007 07:47 PM
Stratocaster
Aug 29, 2005 08:02 PM
