Mase Engineering S2000 Turbo Kit Introduction
Mase,
Has the issue with the filter melting been addressed with your kit yet? These are some quotes that I have found recently concerning the problem.
Inquiring mind wants to know!
Erik
Only issue I've run into so far is the filter has melted where it clams on the turbo. I got a short-term solution I'll be trying here shortly. Turbo sounds badass with no filter though. No, I'm not driving it around without a filter, just a short stint the other day when I discovered it was melted and I took it off to make sure nothing got sucked in.
mase should have told you that i am on my third aem filter this is my new solution i did the other month, since i have had no issues, and removed it the other day to clean etc and no sticking or heat issues melting the filter or silicone hose
Erik
Originally Posted by Enlightened,May 1 2010, 12:38 AM
Mase,
Erik
Erik
They've been using a new AEM filter for months... Never melted. This problems been fixed for a while... I was concurned too. This kit is complete and has all forseable problems worked out. Mase Engineering FTW!
I've been running 14psi for 2 months no problem. Just gotta be careful not to get bad fuel or play too much. I drive my S everyday... And hard! The motors alot stronger then everyone thinks.
Originally Posted by boostftw,May 1 2010, 08:50 PM
someone already has a cracked manifold?
