Mase Engineering Tuned Vortech AP1
Originally Posted by 9kFever,Aug 25 2008, 06:02 PM
Yea, Church has also dyno'd more SC'd s2ks than anywhere else. Good for comparison.
My car did 385whp on the Do-it-Dyno Dynojet which many have said read low. That day modded AP2's (Toda Header, Intake, Exhaust, Reflash) were only doing 210-215. That day my car was running way rich at 10:1. Mase leaned it out 3 times before I dyno'd at Church and it felt better each time. I am guessing it would be about 400whp at the Dynojet now and that would make Church's dyno high by about 8%. Even if you go by the 385 number it is only 11% higher. I will probably go back to do-it-dyno for their 50 dollar dyno day to confirm this. All that being said, I was actually expecting about 440whp at Church so that was pretty close.
Congrats for the results man and I pull my hat for your guts to do it on a stock engine!
Two questions:
1) Do you know to what level did Mase lean you out? 1:12? Do you have the A/F ratio also on print?
2) You're using the 3.9 inch pulley from ASP, according to Sideways post the 3.6 inch pulley from ASP is pushing 14 PSI, not the 3.6 one. Or am I mixing numbers here?
I'm just ordering the 3.6 from ASP, but they themselves don't know what size the belt should be. How should I know this??? What size do you have on the 3.9?
Andreas
Two questions:
Andreas
