Max power for stock comptech S/C
Old Oct 28, 2012 | 05:22 PM
kerm1t's Avatar
Default Max power for stock comptech S/C
With the comptech ESM, for and walbro fuel pump, is it possible to run a smaller ap2 pulley?
since i have fmic so im wondering if its better buying a 4.3" than a 4.6". ill be running stock boost for a while
Old Oct 29, 2012 | 07:41 AM
kerm1t's Avatar
Would a ap2 4.2" comptech pulley work better on a ap1 with fmic and esm
Old Oct 29, 2012 | 09:40 AM
EOE's Avatar
EOE
Check links in my sig. Without esm or piggyback it never worked even tho it was supposed to.
Old Oct 29, 2012 | 11:30 PM
kerm1t's Avatar
I mean with esm.
Old Oct 30, 2012 | 11:34 AM
s2000Junky's Avatar
The base kit makes 5.5psi. With an fmic you will be lucking to see 3psi. It doesn’t matter what size pulley you run, if your motor never sees that pressure then your base system will support it. I would imagine a 3.8-4" pulley form SOS is what it will take to bring you back up to 5-7psi with the base system, with ESM and RRFPR it will handle that no problem. Don’t waste your time looking for the larger 4.2 ap2 pulley. They are hard to come buy anyway.
Old Oct 30, 2012 | 02:51 PM
kerm1t's Avatar
thank you so much! answered everything.
Old Oct 30, 2012 | 03:04 PM
kerm1t's Avatar
is there a 4" pully? sos site doesnt seem to show any..
Old Oct 30, 2012 | 04:41 PM
s2000Junky's Avatar
SOS discontinued a few of these sizes for the novi 1000. Yes there is a 4". You may need to shop around for used however. You can do some searches on other manufactures for these sizes as well. Just make sure its for a Novi 1000 with 7/8" shaft diameter.
Old Oct 31, 2012 | 11:00 AM
jdmdohcpower's Avatar
I have a 3.2 that I just got from SOS. Makes 400whp but thats with EMS, injectors, and 4-bar maf sensor. Upgraded fuel pump is not needed if you use injectors and a tune. But you wont make that kind of power with a FMIC. You need to switch and get an aftercooler. I did and gained 40whp just from that alone.
Old Oct 31, 2012 | 11:12 AM
s2000Junky's Avatar
If you’re going to stick to running stock injectors and RRFPR as the base system comes, then you will need a higher flow fuel pump. This is due to the increased fuel pressure required to run that system with the rrfpr.
s2kbtos
Sep 20, 2013 10:22 AM
SeanSerino
Jun 1, 2011 09:35 PM
SRap1
Apr 2, 2010 09:34 AM
D-04
Jun 12, 2006 08:14 AM
DEEZ
Mar 12, 2006 04:40 PM
