May not be serious, does this happen to you guys?
Old Jun 12, 2013 | 08:14 AM
JDMBLINDIAN's Avatar
Default May not be serious, does this happen to you guys?
So I have noticed that I have had to push my dipstick back down after doing a couple pulls. For example, when I did the half mile shootout, after each run I would have to push my dipstick back down. It wouldn't come out all the way, It would just pop up. im running 14-16lbs of boost on a stock motor/stock compression. May be a noob question, I am just curious if it something serious I should worry about or is it a quick fix.
Old Jun 12, 2013 | 08:20 AM
BuggyofMildDiscomfort's Avatar
Breathers are blocked, or you've got a lot of ring blowby.
baZurk's Avatar
Quick fix is to turn the dipstick around. Long term fix? No clue
Old Jun 12, 2013 | 08:27 AM
passmans2kny's Avatar
get a catch can
Old Jun 12, 2013 | 08:30 AM
Sideways's Avatar
Wipe the O-rings off, wipe out the area where the dip stick goes and it should reduce it. As said above, reverse it. Everybody that is boosted may see this from time to time. I noticed mine the other day.
Old Jun 12, 2013 | 08:34 AM
herecomesboost's Avatar
How are you evacuating crankcase pressure currently?
Old Jun 12, 2013 | 09:03 AM
Piston ring blow by?
Never tried turning it around.
Originally Posted by passmans2kny
get a catch can
any particular brand you recommend?
Ill whip it off when I get off of work. Ill see if reversing it help does the the trick also
I only have a small breather on top of the valve cover.
Old Jun 12, 2013 | 09:17 AM
illestrolla's Avatar
please tell me you don't still have your PCV valve hooked up?
Old Jun 12, 2013 | 09:26 AM
APoner's Avatar
Supra PCV and Catch can?
Old Jun 12, 2013 | 09:29 AM
I suggest ditching the PCV and plugging the nipple on the intake manifold; replace the PCV with this and run some form of catch can.
