To meth or not to meth?
Old Dec 30, 2011 | 01:48 PM
  #21
JoeyBalls's Avatar
What I think is a great idea, is to add the METH kit after the tune, and use the smallest nozzle to inject 100% distilled water. If it fails, no KABOOOM, and as it works it will spray just a little bit to help keep the intake charge cool
Old Jan 1, 2012 | 08:53 PM
  #22
Drkphnx's Avatar
Thanks for the more input everyone, Yes the novi1000 is week but I'm confident it will meet my goals for now. I will be happy with 400 for a while. I've been at 300 for about 5 years. Maybe in 2 or 3 years I'll go novi1200 or even turbo
Joey, I like the idea of using it to further cool the intake charge. I may just do that, thanks
Old Jan 2, 2012 | 09:24 AM
  #23
s2000Junky's Avatar
Being you’re on a 10:1 comp motor, detonation isn’t going to be a limiting determining factor, not that it really was at the oem 11:1 with just a novi1000 at max impeller speed. So now your challenge is going to be touching your goal of 400whp. Since you lost a point of compression, your going to need to make up that lost power somehow. More timing in your tune is going to be the angle you’re going to want to look at, as well as additional cooling. Is water meth necessary with your set up? Not at all. Will you gain more power and have a better chance at reaching your goal? Absolutely.
Water/meth is a science and an art, just like any other tuning, but it has its own set of rules. I suggest you read up on it and get familiar with the different kind of configurations at your disposal and decide how you want to use it. Its something I fully believe in, but its important to understand it yourself, or find a trusting tuner that does, or risk being disappointed. I’m convinced that those who go out of there way to poo poo it, never took the time to fully understand what it can ant cant offer them.
Just a tip, I would strongly recommend staying away from a 'progressive' pump injection kit such as the one AEM offers, for your SC set up. In theory it’s a neat idea, but in my experience it does not deliver safe and consistent injection due to the design. Its design is for the injection pump to spool up and make pressure before injection, when the desired psi is triggered, on a non turbo set up where there is no boost lag/spool up, it creates a delay in injection and erratic lean conditions. I recommend what I use, which is a solenoid controlled injection which has 100% pressure from a recalculating pump that runs all the time, when injection is called for, it instantly delivers 100% pressure and flow. This is more reliable, safer and easier to tune. You can make your own kit for about 2/3 the price as well. Otherwise shop for a single stage, non progressive kit through one of the several companies out there, Devils own, snow performance, to name a few.
Old Jan 3, 2012 | 11:39 AM
  #24
donaldmejr's Avatar
I told you he would reply.
Old Jan 3, 2012 | 11:44 AM
  #25
passmans2kny's Avatar
hahahahahaha
  #26
spectacle's Avatar
rofl
Old Jan 3, 2012 | 01:44 PM
  #27
s2000Junky's Avatar
Well of course, I am the saint of meth injection. But I do not indorse AEM kits in anyway
Old Jan 3, 2012 | 01:49 PM
  #28
camuman's Avatar
This thread just reminded me I have an aem meth kit on my car that just comes along for the ride. Have not and will not be using for this or future setups. E85 is in my future.
Old Jan 3, 2012 | 01:52 PM
  #29
s2000Junky's Avatar
Depending on how much boost lag you get with your set up, it would likley work better for you then me.
Old Jan 4, 2012 | 10:19 AM
  #30
siadam's Avatar
Originally Posted by passmans2kny
Go e85 not meth
Race gas 110+ > e85 > methanol/water
I've had some rather unfortunate misfortunes, but I attribute both of them to my fault.
rikhemi
Mar 16, 2014 06:15 PM
Titounais
May 15, 2006 02:18 PM
bumpins2k
Aug 20, 2005 04:30 PM
D-S2K
May 24, 2005 12:04 PM
speedy4cyl
Apr 4, 2004 08:34 PM
