Misfire on all cylinders
Old Aug 8, 2011 | 10:40 PM
  #31
donaldmejr's Avatar
guys thanks for all your help!!! I have been fighting with this since day one and would hate to lose my motor because me or a shop can not figure it out.
Old Aug 9, 2011 | 07:16 AM
  #32
camuman's Avatar
So plugs are not problem.
Timing is not problem.
Fuel is not problem. Did u check injectors? Might be a failing one
Pump pressure good in boost? Well I think hiccups happened part throttle too so that shouldn't be it.
I'd say either injectors or map file, or ur ecu is issue. Maybe a grounding problem in car.
Old Aug 11, 2011 | 02:52 PM
  #33
donaldmejr's Avatar
Guys Im wondering if rewiring the fuel pump is needed for 500-550whp? I never rewired mine could that be a issue?
Fuel setup:
FB340 fuel pump
InlinePro Return Fuel kit
ID1000's
104 unleaded fuel
base fuel pressure at 60psi
Old Aug 11, 2011 | 02:54 PM
  #34
camuman's Avatar
No cause u have problems part throttle.
Old Aug 11, 2011 | 02:57 PM
  #35
Deception's Avatar
Originally Posted by joefish1298
Originally Posted by s2000Junky' timestamp='1312513318' post='20849195
[quote name='donaldmejr' timestamp='1312511205' post='20849126']
issues *snip*
*snip* have you considered running water/meth injection instead? it is more versatile, being you can play with different % to help trouble shoot things like this. A higher % of meth obviously burn better then water. Might just have to get tuned on pump and see what happens, that should tell you if its engine related or spark capacity.
[/quote]
Im going to be an internet legend one day for that pic
Old Aug 11, 2011 | 03:29 PM
  #36
camuman's Avatar
Originally Posted by Deception
Originally Posted by joefish1298' timestamp='1312530172' post='20849820
[quote name='s2000Junky' timestamp='1312513318' post='20849195']
issues *snip*
[/quote]
[/quote]
Old Aug 13, 2011 | 07:04 PM
  #37
urBan_dK's Avatar
Checked all the vacuum lines for cracks or leaks? I had a vacuum leak that caused me misfires at part and WOT.
Old Sep 3, 2011 | 06:10 AM
  #38
TonysMI4's Avatar
Any updates??? im starting to get the same thing.
Old Sep 3, 2011 | 02:53 PM
  #39
donaldmejr's Avatar
since ive done my upgrades to the car i have went through and redone all and vacuum lines hose clamps and replaced the map sensor all at once. no misfires in ~150 miles but has been cool out also.
Old Sep 6, 2011 | 06:18 AM
  #40
fmfkid250's Avatar
I was the one helping with this. Very odd problem. The BOV is Very Noisey. I was thinking it was picking up the vibration and it was "thinking" it was a misfire.
It dident seem to do it at WOT, just normal driving "kinda fast" it would start to blink. I Pulled timing to see if it was maybe knocking but nothing helped. We even swaped in RSX coils out of my S2000 to see if it made the difference. and nothing....
Glad to see it's been good.
