Modding the stock Airbox for turbo application
Old 06-26-2018, 01:11 AM
  #21
RolanTHUNDER's Avatar
Nguyen I notice your turbo is in very close proximity to your valve cover and the hot side is uncovered. Doesn't that pose a threat to your VC (paint peeling off at the very least)?
Old 06-26-2018, 04:48 AM
  #22
nguyen365's Avatar
Originally Posted by MARK AUS S2K
How will the cold air enter this box? There needs to be a large open section of the front bumper located right where the H badge lives. The large grille should be ducted up and over the radiator frame and into a sealed insulated box where the intake filter lives.
Stainless Steel filters have also proved to be the best for making more power.
the stock airbox has an inlet which lies just above the radiator
so it doesn’t suck in the the warm air coming from the inter
cooler and radiator. Optimal cooling would be if there’s an inlet from the hood but don’t feel like cutting the hood now
Old 06-26-2018, 04:50 AM
  #23
nguyen365's Avatar
I used to have a Dei titanium turbo blanket it lasted 3 months as it melted away. What a waste of $300. Valve cover paint still fine after 6 months
Old 06-26-2018, 07:35 AM
  #24
hatrickstu's Avatar
What are your actual inlet temps after the intercooler? What intercooler are you using?
Old 06-26-2018, 08:13 AM
  #25
nguyen365's Avatar
Just did some more modding to the stock airbox
Old 06-26-2018, 08:23 AM
  #26
nguyen365's Avatar
[left]
But it looks so good with the turbine showing tho I might end
up goin with a mesh lol and ac reroute and turbo water line
Old 06-26-2018, 08:54 AM
  #27
nguyen365's Avatar
Scrapped the project might look into someone to fab an
alumimun airbox down the road
Old 06-26-2018, 08:57 AM
  #28
nguyen365's Avatar
the stock airbox inlet sit slightly on top of the radiator I have the 750hp precision radiator
Old 06-26-2018, 09:09 AM
  #29
Mijae007's Avatar
Wow this is macguyver at its best lol. I like the idea of using an airbox but not like this, that tape is sure to fail at some point with all the heat and suction.
Old 06-26-2018, 10:38 AM
  #30
hatrickstu's Avatar
Not what I asked lol. Are you actually logging and seeing issues with IAT after the cooler? I REALLY doubt you are having IAT issues post cooler at your power level and that IC.
Quick Reply: Modding the stock Airbox for turbo application
