Modified OEM fuel tank baffle with trap doors
any thoughts on the Holley hydramat? https://www.holley.c...stems/hydramat/
The small slit in the bottom of that basket is not big enough to feed a 255 pumped to an empty 5 gallon bucket. With a fuel level at the top of the basket on the outside of the basket, the pump would run the basket dry waiting for fuel to enter the basket through the slit.
I'm trying to avoid the surge tank not that I don't like them, I don't want to lose any more trunk space or get fuel smell in the car. For a street car I want to stay with a in tank pump setup, I know it's more work but it will be worth it if it works like I think it will. You guys must also remember that the fuel returning back to the tank is also filling the baffle.
Messing with the fuel tank seems like more trouble than it's worth. It might not even be as effective as a fuel surge tank in the end. I run a surge tank and used to run a FB hanger (which I need to sell). I got fuel smell with that setup since the epoxy for the wiring needed to be redone. I run PTFE hose with my fuel surge tank and have no hint of feel smell. You can mount a surge tank under the car where the fuel canister is located.
Originally Posted by staylor725' timestamp='1467070765' post='24003914
I have all the parts needed for this just want to post this before getting started to hear others opinions.
This was bench tested, with no side load a car experiences to splash fuel back into the basket from the top.
Yes I am sure. Read my statement again. With the fuel level in the tank below the height of the basket inside the tank where the filter sock sits. A 255 pump running into a 5 gallon bucket, it sucked the fuel out quicker than the fuel in the tank could re enter the basket through the slit in the side.
a 255 pump with 0 fluid pressure on the outlet will flow a lot more fuel vs running to a regulator set at 40-60psi. This is probably why my example above was found to be true.
I never said surge tanks do not work, where did I even come close to saying that? All of my posts in this thread are referring to a 100% stock fuel system on an S2000 aside from a 255 pump used to test a theory. Yes, you would be on "E."
