mods effect the accuracy of speedometer?
Old Mar 28, 2009 | 10:05 PM
soccer4life's Avatar
Default mods effect the accuracy of speedometer?
Ok i know this sounds like a dumb question but i have never boosted a car before and had large power gains. and on mt 2001 ap1 im thinking of doing the IP gt35r kit and i dont know what that will do to my stock guages accuracy? any help on things that will also effect the accuracy would be appreciated and also ways to tweak the guages or w.e to get back to accurate readings.... thanks in advance
Old Mar 28, 2009 | 10:08 PM
DFWs2k's Avatar
what gauges are you concerned about? speedometer will stay as accurate as it was out of the factory provided you keep the same aspect tires and gears....
temp will obviously (or maybe not so obviously) stay as accurate as it is provided you don't change any temp related parts or go to AEM...
can you be more specific about what you are specifically worried about?
Old Mar 28, 2009 | 10:21 PM
ok well when i have talked with people like when they do engine swaps and shit like that theat the guages will be out of sync such as the speedometer will be inaccurate. that is my major concern. by no means am i saying that it is tha way im curious because im new to this scene if u will.
Old Mar 29, 2009 | 12:03 AM
nightcrawler7188's Avatar
engine swaps the gauges should still be accurate if the same sensors were retained. speedo will be inaccurate only if you make changes to the final drive gear or wheel/tire sizes
Old Mar 29, 2009 | 12:50 AM
AusS2000's Avatar
Speedometer will climb much quicker.
Old Mar 29, 2009 | 07:13 AM
ChefJ's Avatar
^ Agreed.
Also if yo udo go with AEM and upgrade the valve train your tach won't handle the revs...
Old Mar 29, 2009 | 07:15 AM
Soul Coughing's Avatar
tire ratio, rear end changes and swapping tranny's will all change the speedo. Using a GPS will tell you how far off the two are.
Old Mar 29, 2009 | 10:23 AM
ok i was looking at changing out the lsd because im planning on doing some rough launches and i keep seeing that with soem companies with the lsd it comes with a final gear drive. so that will change my speedo? likewise what is the final gear drive
JoeyBalls
Aug 31, 2009 04:54 PM
S2KVITO
Dec 5, 2007 10:57 AM
IzMoskvi
Dec 8, 2005 07:23 PM
FiLi
Nov 22, 2004 05:49 AM
Strike
Apr 29, 2003 06:56 PM
