MORE starting issues
Originally Posted by spectacle,Sep 22 2010, 09:16 AM
How much did you test? There's no magic number for those fields, you have to constantly mess with them according to how the car acts at those temps when starting.
Sadly there is no consistency with IAT Comp Values. For example, when I go to start my car after work tonight I'll read IAT at approximately 87' and the car will take 5+ seconds cranking to start. Yet I'll drive it home, shut it off with IAT reading 93' (same column), wait a few minutes and it will fire right back up without problem.
this is an easy answer.
swap motors with me. dont think about how it will help, just trust that it will
sucks you cant enjoy the car yet. i would be extremely pissed if it wouldnt start each and every time i cranked it. have you put a fuel psi gauge on to see whats going on during the prime, running, and off sequences?
During the times when you think its going to be hard to start, hold the gas open before starting it and see if it starts faster. If it does you need to pull more injector pulse out at the temp. Doesn't = opposite
Dunno if that's going to be a valid test with the DBW cars (dunno if the ECU will open the throttle without the car cranked on), but it certainly works on cable cars
DFWs2k - I haven't driven my car in almost 4 months. When it was running, I was still in the process of dialing it in with JustinC's help. We were getting pretty good at getting it to start consistently no matter the temp or condition. Look for my massive rework thread coming in the next few weeks where I outline this issue and illustrate the changes made.
Nope, no luck. Attempting to use this doesn't work, datalogs still show the injectors receive a pulse.
No, not what I was talking about. Holding the throttle open leans out the A/F during cranking but you're allowing my air into the cylinders. Won't change the injector puleses or the amount of fuel sprayed, only the amount of air during initial start
Ok guys, just ran out to my car on lunch break. Attempted cranking for approx 4 seconds before I began to depress throttle slowly. After about an additional 4 seconds and roughly 90% throttle the car fired.
Total Crank Time : Approx 8 seconds.
