Motor failure on the dyno today
Old Jul 28, 2009 | 09:26 PM
  #51
m R g S r's Avatar
I have a spare head in my basement, and I'm 99.9% sure that my head is still good. So no way I'm spending 2800 on a new motor. I'm hoping to get this fixed for a few hundred by either replacing the piston and rings or buying a new (used) shortblock. If I was shelling out 2800, it would be on a fully built bottom, and I would slap the stock head back on. but thanks for the suggestion!
Old Jul 28, 2009 | 10:10 PM
  #52
s2000Junky's Avatar
Money doesn't go as far as it sounds like you think it does with this motor. Something to be said for a complete un cracked motor. If you have the time to build an engine yourself and then put it in then more power to you, it might be worth justifying. Doing the complete motor swap took enough time and aggravation in my life without spending the money and time to piece together my motor first and then do the swap. Bummer deal this is, I know first hand, hope you find a good solution soon so you can get back on the road asap
Old Jul 29, 2009 | 06:33 AM
  #53
Soul Coughing's Avatar
sorry to hear about your loss. I see you have an '02. Did you change the oil banjo bolts? Can you get the EMS maps from your tuner? Did he check the plugs inbetween runs? When you looked inside the cylinder, did you see scores on the walls? At idle was the motor shooting smoke out the breather hose?
Old Jul 29, 2009 | 06:40 AM
  #54
nrgtechmiller's Avatar
Evan, You are more then welcome to post screen shots of the timing and fuel map within the ecu. I wont have hard feelings. I dont lock my tunes like other tuners.
You were there with me and saw the plugs how they came out from the 2 previous pulls and like I said the only change after all was looked over was vtec. You also saw the plugs that I pulled out of the engine before I even started tuning and the way those looked. I took every precaution I possibly could have to prevent any type of damage happening. I even said to you on numerous occasions after we started hearing the noise that I was nervous that I really dont like to see things get hurt when I am involved.
Old Jul 29, 2009 | 06:49 AM
  #55
s2000isu's Avatar
It will be interesting to see what actually failed. Very cool of the tuner to come on and suggest you post the maps up for everyone to see. Sounds like a guy that stands behind his tune to put it on the spot like that two thumbs up.
Old Jul 29, 2009 | 10:43 AM
  #56
AndyFloyd's Avatar
Originally Posted by Momentum,Jul 28 2009, 02:24 PM
Or a non resistor plug. Unless you have wiring issues you do not need a plug with a resistor. I have more electronics on my car than anyone on this forum with the exception MAYBE of tony from T1 who I doubt runs resistor plugs in his car. I also run non resistor plugs in my DD S2000 and have no issues with either car.
Technically that's not true anyway the plugs out of a rotary (surface discharge) are resistor and would work in our application.
same here, non resistor heat range 8 NGK.
Old Jul 29, 2009 | 11:24 AM
  #57
siadam's Avatar
Originally Posted by pwrofdrm,Jul 28 2009, 12:54 PM
Can't believe I'm the first one in this post to say this... Miller doesn't exactly have the best reputation for a tuner or engine builder. There are quite a few horror stories floating around about his work, including the time he installed a set of k-series pistons backwards for a customer.
Do a quick google for NRG Tech and you'll see I'm not just some trash-talking troll. I typically keep my thoughts to myself, but in this case it seems you didn't know...
I wasn't aware of that...
Old Jul 29, 2009 | 11:29 AM
  #58
m R g S r's Avatar
Well I opened the motor....
EVERY single piston is melted on the intake side, exhaust side is fine. And the cylinder wall on the 4th cylinder is toast, there is a crater melted out of the top part of the wall. I took some detailed pics to post, but I'm on the way to work in a sec (need $$ to get a new motor now ughh), don't have time now. I will post them up later tonight.
Old Jul 29, 2009 | 11:42 AM
  #59
spectacle's Avatar
Sounds knarly! Can't wait to see the carnage...
Old Jul 29, 2009 | 12:09 PM
  #60
AndyFloyd's Avatar
oh wow. Only on the intake side....thats odd. It was seeing some really high cylinder temps...sounds like detonation was happening REALLY bad to melt forged pistons like that. In for pics as well, sorry man...i feel for ya.
