Motor failure on the dyno today
Originally Posted by stitos2k,Jul 30 2009, 11:15 AM
Says he's running a 2002 in his profile, pretty sure Honda had moved all the s2k's to the new banjo bolt by then. I think only the 2000 and 2001 had the old bolts.
Sorry I didn't answer, I know you were trying to help.
The banjo bolts would have nothing to do with this. The tops of each piston are melted and those never see any oil, so that would not be the problem. I didn't change the banjo bolts, and I am not sure if the previous owner brought it to honda for the recall.
Na I have a lot of confidence in a stock motor, this was obviously not a weakness of the motor's internal components. Even aftermarket pistons would have failed in this situation.
I just need to find the cheapest way to get another stock motor up and running. Probably with some arp's.
Is there anyway to test the gas that is in the tank? To see if it was a lower quality than it should have been?
For the aluminium to melt like that, the temperatures in the combustion cylinder would have to get very hot! Whatever you do, make sure you check all parts of your system before throwing a new motor in. Good luck!
Originally Posted by m R g S r,Jul 29 2009, 04:00 PM
I know and I don't get it. A brand new wideband o2 sensor was used and the afr's never spiked during the last pull. I can't think of what would cause this. Bad gas possibly? I filled it with 93 right before I left.
