moving compressor side of turbo
Old Dec 16, 2013 | 10:00 AM
lude92_si's Avatar
Default moving compressor side of turbo
Doing a Turbo build and the outlet on the Turbo is almost hitting my vtec solenoid. Can I just loosen up the bolts behind it and turn it? Is there any seals I have to worry about. Just need to move it a .5-1".
Will this be ok?
Attached Thumbnails moving compressor side of turbo-forumrunner_20131216_140006.png
Old Dec 16, 2013 | 10:24 AM
il_robu89's Avatar
is man no prob..! i've had the same problem on my afi kit!
Old Dec 16, 2013 | 11:24 AM
baZurk's Avatar
Yup, just loosen those bolts and turn the compressor housing.
Old Dec 16, 2013 | 11:25 AM
lude92_si's Avatar
This wont cause any damage or leaks?
Old Dec 16, 2013 | 11:30 AM
baZurk's Avatar
Not that I know of. I looked it up on youtube
Old Dec 16, 2013 | 11:52 AM
lude92_si's Avatar
lude92_si's Avatar
Guess I will find out. Just moved it
Old Dec 16, 2013 | 11:58 AM
baZurk's Avatar
Based on what I have seen, that is the way to do it. I had to clock my compressor housing a bit for the compressor outlet to clear my manifold.
Old Dec 16, 2013 | 12:23 PM
herecomesboost's Avatar
The compressor housing, center cartridge, and exhaust housing can all be rotated independent of each other. Just don't go nuts when re-tightening the compressor housing bolts (the cover is aluminum).
Old Dec 16, 2013 | 12:37 PM
baZurk's Avatar
I think manufacturer spec was 6-8 ft/lbs. They break loose very quickly because of the soft metal
