moving compressor side of turbo
Old Dec 16, 2013 | 01:45 PM
Jaspah's Avatar
Howmany Nm is that?
Gotta love the metric system
Old Dec 16, 2013 | 02:42 PM
d-bo's Avatar
mine was leaking i found even after re-torquing them to spec. put a thin ring of copper rtv around the "housing plate" as well as the bolt holes and it will seal it right up
Old Dec 16, 2013 | 03:34 PM
herecomesboost's Avatar
Originally Posted by Jaspah
Howmany Nm is that?
~8-10 Nm
Old Dec 16, 2013 | 04:40 PM
Suzuka_Joe's Avatar
if its a precision i'd just remove the compressor instead of rotating it. I ended up messing up the oring around it and had to buy a new one. $3 part but a pita none the less when i rotated mine after getting it back from precision
Old Dec 16, 2013 | 05:11 PM
Good point. If you're going to rotate the housing, be sure the bolts are loose enough to allow the the housing to rotate freely.
Old Dec 16, 2013 | 05:54 PM
lude92_si's Avatar
It moved pretty easy. So I think it will be fine
Old Dec 16, 2013 | 06:17 PM
Suzuka_Joe's Avatar
yea mine didn't..
Old Dec 17, 2013 | 02:46 AM
Jaspah's Avatar
Originally Posted by herecomesboost
Originally Posted by Jaspah' timestamp='1387233923' post='22925580
Howmany Nm is that?
~8-10 Nm
That's not a lot btw
Add loctite?
Mijae007
Apr 30, 2011 11:20 AM
H4RD ON
Feb 22, 2011 02:49 PM
Deception
Jun 23, 2010 12:24 PM
AusS2000
Feb 11, 2010 09:04 PM
ChefJ
Jun 20, 2007 06:08 PM
