My air pump exploded
Old Jul 20, 2010 | 05:16 PM
PUNCHIN-IT's Avatar
Default My air pump exploded
My air pump burst a hole and the black plastic melted away. Does anyone know how this could have happened?
Old Jul 20, 2010 | 05:18 PM
m R g S r's Avatar
too much boost
Old Jul 20, 2010 | 05:49 PM
PUNCHIN-IT's Avatar
Originally Posted by m R g S r,Jul 20 2010, 09:18 PM
too much boost
Is that really why?!
I knew I should have just removed the dumb thing. What a waste.
Old Jul 20, 2010 | 06:47 PM
DFWs2k's Avatar
pretty sure that's not why, but in for answers, I got my old one if you need one
Old Jul 20, 2010 | 07:12 PM
PUNCHIN-IT's Avatar
I wonder what caused it. If anyone knows please tell me. Because if it is prone to happen again I am not going to replace it. I might just fool the ECU like others.
Old Jul 20, 2010 | 09:21 PM
D1sclaimer's Avatar
What ECU are you running and will you need to pass an OBDII emissions check?
With my AEM, I just installed a 16 dollar block off plate and removed the air pump, valcuum lines, solenoid, EGR(air recirc valve), and had no issues.
Old Jul 20, 2010 | 09:28 PM
AusS2000's Avatar
I take it we are talking about the Secondary Air Injection System pump in the left front behind the front bar? You realise that a turbo is an 'air pump' too?
It is low pressure so it's not too much pressure.
And no boost gets to it. The valve may be on the intake manifold but feeds through the back of the head to the exhaust ports. It never sees charge air until it has been combusted. And if it was exhaust leaking back through the valve it would effect some of the rubber piping too.
So I'm guessing it is simply and electrical failure in the pump motor.
Old Jul 21, 2010 | 07:11 PM
PUNCHIN-IT's Avatar
I have the Greddy Kit and the car is tuned on E-Manage.
Yeah, I need to pass OBD. My next inspection is due September.
Plus, CEL's are very annoying.
Old Jul 21, 2010 | 07:18 PM
PUNCHIN-IT's Avatar
Yeah...the secondary air pump is what I am referring to.
I see what you mean. But, what could have malfunctioned to cause this? I've checked surrounding tubes, pipes, etc. No damage and everything seems like it is in good working order.
I'll post some pics tomorrow, maybe that will help.
I want to get this fixed before my next inspection. But, I don't want to buy another air pump and have that one blow up too.
If anyone else could chime in that would be great. Thanks.
cthree
Apr 12, 2024 08:51 AM
LeechApple
Feb 10, 2014 01:42 AM
lotus7racer
Sep 21, 2012 09:37 AM
s2kseven
Dec 15, 2011 08:46 AM
sbrodacz
Mar 3, 2009 06:55 PM
