My Ap2 Dyno
Old Apr 4, 2008 | 08:39 AM
JoeyBalls's Avatar
Post My Ap2 Dyno
Ok, I removed the Test Pipe, so far with Invidia V3, Stock cat & Base Tune, MAX HP was 267HP, the Vtec Dip is not as bad as AP1's so I am pretty happy with the results so far, Toan is going to do his thing now, hopefully with my manual Boost Controller the BOOST stays around 10PSI, but I will update everyone, as well as post the graphs when I get home tonight
Though I don't have a graph of the base tune, it was 267WHP
Old Apr 4, 2008 | 09:17 AM
ZSAK's Avatar
any updates?
Old Apr 4, 2008 | 09:31 AM
Revenge's Avatar
Cool, I did not know you switched post. That's good 267 hp on that load bearing dyno which reads 12% lower than the dyno jet and others. So you add 12% to your number and your at 299hp dyno jet adjusted.
Old Apr 4, 2008 | 09:33 AM
JoeyBalls's Avatar
not yet......... I hope to safely be around 290WHP, seems like it would of been very easy if I left the Test Pipe in, however I was creeping up to 12PSI I should of went with a test Pipe and stock Exhaust.......oh well, you live and you learn.
devs2k's Avatar
if possible, ask him what a STOCK ap2 does on his dyno.. that would be a great comparison
Old Apr 4, 2008 | 09:34 AM
JoeyBalls's Avatar
good idea, not sure if he would know, but I will ask him, the suspense is killing me
Old Apr 4, 2008 | 09:38 AM
devs2k's Avatar
remember,
Old Apr 4, 2008 | 09:39 AM
JoeyBalls's Avatar
very good point.
Revenge's Avatar
Joey, also ask him about the use of a high flow cat and the V3 if he thinks it will be too much flow. I don't want to put this thing on this week end and have problems with the wastegate overboosting. I am hoping these two will be the sweet spot for max air flow without problems.
Old Apr 4, 2008 | 09:42 AM
JoeyBalls's Avatar
I will, I think that may just work in warmer temperatures, like I said I was not creeping past 10 when it was 60F out, but anything colder it shot way up, the High Flow Cat may have just enough restriction, although it is said to flow as mush as 87% of a Test Pipe, so I don't know if the 15% or so more restriction will cause enough backpressure for the wastgate
