My Custom Turbo Setup
Old Apr 2, 2009 | 06:05 AM
  #91
camuman's Avatar
Originally Posted by 03supers2k,Apr 2 2009, 12:43 AM
I haven't installed the kit yet but the turbo is a Garrett GT35R and my goal is 400 @ 12-13psi. The person i bought it from made 322 @ 8psi with a conservative tune. I cant decide if i should get 650 injectors or 750 with or without 3mm hg to make 400+
if your running a log mani, that turbo is too big for 400hp max. it will spool so much later. def do the 750 injectors. that gives you room down the road. persoanlly, i would stop woprrying about the 3mm HG and the meth. with a solid tune there is ZERO reason to have it with the stuff you are talking about.
on 8#, i made 350 with a lot of low end grunt. now i am on 9# and should be just south of 370. my buddy is about to go with a gt35 and equal lenth mani and he is shooting for 500 on stock stock stock block. its been done many times, and as long as the tuner is worth a shit, car should be fine.
and if possible, and your truly only wanting only hi 3's low low 4's, swap that turbo for a gt30r. you will have much better power band on that mani, if again it is a log mani.
good luck.
Old Apr 2, 2009 | 06:12 AM
  #92
JoeyBalls's Avatar
Originally Posted by JDM_EM1,Mar 31 2009, 07:00 PM
the water/meth kit is gonna add power regardless with a tune. my main concern is being able to run more boost on pump gas with high compression and keeping it safe. water/meth lowers the chance of knock and denotation which becomes a bigger problem when running high boost levels on high compression. power gains are just a plus for me
I think every TURBO application should be using Water/meth, or maybe just water at the very least, its an amazing thing........
Old Apr 2, 2009 | 11:35 AM
  #93
JDM_EM1's Avatar
i also agree that a gt30 would be a much better choice for your powergoals, especially if its a streetcar/daily driver. i would also deff do 750s, just because u have room to upgrade. keep the stock hg and find a good tuner.
Nice job!
Did you buy one of those universal piping kits for the intercooler piping and cut and weld to make it fit perfect or did you buy a already made setup?
It looks like a great job!
thanks. i just bought some mild steel bends, 45s ,90s and 3ft of straight. Fab'd it all up and had a friend weld it together.
Old Apr 15, 2009 | 04:20 PM
  #94
JDM_EM1's Avatar
New pics my boy shot today
Old Apr 15, 2009 | 04:28 PM
  #95
Revenge's Avatar
Did you have to cut out part of your bumper to fit the exhaust in. Also it loks like your lowered does the exhaust have enough clearence? Nice pics
Old Apr 15, 2009 | 04:58 PM
  #96
JDM_EM1's Avatar
nah the exhaust cap is just alil melted from the exhaust. it scrapes alil on hard bumps
Old May 14, 2009 | 09:02 AM
  #97
JDM_EM1's Avatar
just alil update, ran a 12.9 @ 110 at the track 2 weeks ago...
Old May 14, 2009 | 09:40 AM
  #98
AndyFloyd's Avatar
i woulda thought the trap speed would be better but still not bad. What was your 60' and boost pressure at the track....etc? 12's is still good though
Old May 14, 2009 | 09:41 AM
  #99
passmans2kny's Avatar
dam that can sits low
Old May 14, 2009 | 09:44 AM
  #100
AndyFloyd's Avatar
mine sits low as well...looks about like his. Im not lowered...so i never scrape, i bet the OP has scraped once or twice. Looks good at that angle though.
