My ebay heat exchanger
Old Mar 7, 2012 | 09:57 AM
  #21
jordannn93's Avatar
Originally Posted by jsenclosure
The bosch cobra pump?
Do you have any pictures of this install?
thanks
Yes the cobra, and I don't have any install pictures. It is pretty easy, a few posts up is a picture of what I did so I could mount it. Just got a piece of aluminum welded on each side of the heat exchanger, drilled a hole in each one and bolted it up.
Old Mar 7, 2012 | 03:08 PM
  #22
cariza's Avatar
I bought the same heat exchanger also. Thanks for this info. I installed and Im currently tuning. Im seeing AIT at no more than 90F under WOT. The vortech one that came with the kit was about the same dimensions as this one but the inside honeycomb was much smaller. The ebay one weighs twice as much as the vortech. Also installed the BOSCH water pump. Check some install pics at my post:
https://www.s2ki.com/s2000/topic/934...-v3-build-ap2/
Old Mar 7, 2012 | 04:10 PM
  #23
james0933's Avatar
Any easy mounting solutions with pics?
Old Mar 7, 2012 | 05:00 PM
  #24
jordannn93's Avatar
Old Mar 7, 2012 | 05:28 PM
  #25
Deception's Avatar
Originally Posted by donaldmejr
nice I want to upgrade my SOS HE to this one
http://www.siliconei...ccf80151c8d4a6d
looks good, I like how it has a drain & temp sensor bung.. maybe I will get one of these & a better pump
Old Mar 7, 2012 | 08:23 PM
  #26
teamvalorracing's Avatar
i wonder if the op has trouble with his engine running hot since the ac blocks almost all airflow at those dimensions.
Old Jul 29, 2012 | 02:12 PM
  #27
E4RTH WORM JIM's Avatar
Can someone please give me more details on the water pump needed for the bigger aftercooler.
Is my current Comptech water pump not big enough?
Any links of advice will be much appricated!
Old Jul 29, 2012 | 03:36 PM
  #28
jordannn93's Avatar
I used the Bosch cobra water pump. It worked good.
Old Jul 30, 2012 | 01:52 AM
  #29
Is this the right one?
http://www.ebay.com/itm/Bosch-Cobra-...a2541e&vxp=mtr
where did you buy yours from?
Old Jul 30, 2012 | 07:38 AM
  #30
jordannn93's Avatar
Yes that's it. Bought it from eBay from the same person. ZZp are good people.
