My fuel system
Old Oct 22, 2008 | 04:19 PM
  #41
GDM S2K's Avatar
Originally Posted by btstone84,Oct 22 2008, 11:24 AM
just a timer. somewhere between .1 sec and .9 sec. have to play with it to figure how long before i want to come on. but i will not run through ems. my bro has a progressor kit(he runs out of motor on the other end, so he need all the juice he can get by the finish line [small block 400]), but i want it all at one time to cut the 60ft and 330ft down more.
but this is down the road....gotta get the 10 first
ah got ya I thought you were going to squeeze right as you hit the gas. like launch on the bottle.
good luck none the less, get to that magic number and a beers on me on cloud 9
Old Oct 22, 2008 | 04:30 PM
  #42
GDM S2K's Avatar
should have first start on sat
Old Oct 22, 2008 | 05:46 PM
  #43
btstone84's Avatar
i dont drink....but ill take a sweet tea
is that your motor...beautiful set up......after InlinePro does my tune monday, i will post pics of my motor.
i dont drive the car hardly ever, but here it is just in regular form.
Old Oct 22, 2008 | 05:52 PM
  #44
GDM S2K's Avatar
looks nice and clean. Yup that's mine thanx for the compliments. Hopefully all works out
Old Oct 22, 2008 | 05:55 PM
  #45
btstone84's Avatar
i like your fuel set up too. thats how my old man runs his on his camaro. here are some shitty pics of mine
Old Oct 24, 2008 | 06:12 AM
  #46
snakeeater's Avatar
Do you currently have a sump between the stock fuel tank and the fuel pump? Or did you add a "semi-sump" (like Full Race offers) to the bottom back of the stock fuel tank? Or did you just drill a hole at the bottom back of the stock fuel tank to feed the suction of the pump?
I agree that replacing the stock fuel tank with a fuel cell is the obvious "pro" upgrade. I keep seeing custom-fit (or at least altered) aluminum fuel cells in the S. Do none of the off-the-shelf polypropylene cells fit in our car?
Old Oct 24, 2008 | 06:33 AM
  #47
GDM S2K's Avatar
ive got the full-race sump on my stock tank
Old Oct 24, 2008 | 09:33 AM
  #48
ERL_S2000's Avatar
Do you have a pic of that?
Old Oct 24, 2008 | 09:52 AM
  #49
AndyFloyd's Avatar
GDM what turbo are you using?
Old Oct 24, 2008 | 09:56 AM
  #50
GDM S2K's Avatar
yes ill have to post it when I get home, its a super tight fit with the fitting, we had to remove the strraight -10 and put a steel 90 degree -10 to fit it
