is my oil psi high or is this normal?
Old Aug 5, 2013 | 06:33 PM
hybrdthry911's Avatar
Originally Posted by GrandMasterKhan
40psi when warm.
That seems rather high even with plugged squirters.
Old Aug 5, 2013 | 07:03 PM
GrandMasterKhan's Avatar
actually it looks like it usually settles around 36-40 around idle.
Old Aug 6, 2013 | 04:07 AM
herecomesboost's Avatar
Old Aug 6, 2013 | 10:19 AM
rrounds's Avatar
Do you know what the oil temperature is when you take the oil pressure readings? If the oil is warm(not hot), that can give you a higher reading than when the oil is hot(230+ deg's).
ROD
Old Aug 6, 2013 | 11:18 AM
i have an oil temp gauge. I guess what has been worring me the most is that when the oil is cold my gauge will peg 100psi. I wish I had a gauge which could reader higher (my autometer cobalt only reads 0-100psi)
What are you guys seeing with cold oil psi at startup?
Old Aug 6, 2013 | 11:27 AM
rsmatti's Avatar
That just means you have 1000HP.
Old Aug 6, 2013 | 12:27 PM
rrounds's Avatar
My S is stock and it goes a little over 100 psi on cold start up. I wouldn't worry about 100 psi on cold oil. I've seen some S's that have 10 psi(or a little less) at idle when hot and these guys track their cars with no engine problems, because their oil pressure is good at just about any rpm above idle.
ROD
Old Aug 6, 2013 | 01:30 PM
My oil pressure is 85-90+ on cold starts; 15-20psi at idle (when hot)
Old Aug 12, 2013 | 09:05 PM
stantaur's Avatar
25 PSI idle warm, 90-ish in 3000 RPM cruise, 10w30 Mobil 1 per BobIsTheOilGuy My link
Laskey block, rebuilt with oil squirters by Portland Speed Industries Aug 2012.
Oil sender at remote adapter inlet.
Old Aug 13, 2013 | 09:56 AM
I rechecked it. It is actually 90-98 psi when crusing around town once the oil is hot.
When the car is cold the oil psi gauge is usually pegged at over 100psi??. until the oil starts to warm up.
Charper732
Aug 21, 2017 02:06 PM
liquid_helix136
Sep 4, 2013 08:25 AM
ChefJ
Jul 29, 2010 05:24 PM
josserman
Apr 24, 2010 10:59 AM
driftintherain
Dec 10, 2008 08:59 PM
