My rebuild thread
Old Jan 22, 2011 | 09:14 PM
dibi's Avatar
Default My rebuild thread
Well i have started to rebuild my turbo s again. I had some 3mm HG problems that finally got the best of me so i pulled the motor and had it rebuilt. I also started a wire tuck and shaved the engine bay. My plan is to upgrade to a gtx3076r from my gt3076r with water meth and larger injectors (id 1000's) then a its off for a retune.
before pic
before dyno dotted line
here are a few pics of the progress
bore and hone
mahle pistons 8.9 cr
acl bearings
bc rods
balance/blueprint etc
engine bay. I am really new to welding so progress is slow but i am starting to gain some ground now. The metal work is almost done, maybe two days left before i start with the body filler and tons of sanding
Old Jan 22, 2011 | 09:35 PM
EternalLx's Avatar
Cant wait to see the new numbers and engine bay!
Old Jan 23, 2011 | 05:57 AM
passmans2kny's Avatar
nice build, i also wanna upgrade from a gt30r to a gtx30r, or is it gt30xr? gt30x? not sure but i want the same turbo, good luck
Old Jan 23, 2011 | 06:02 AM
GO-AUTOWORKS's Avatar
very nice!
Who assembled/machined the block for you?
Old Jan 23, 2011 | 11:24 AM
dibi's Avatar
Thanks everyone!
"wadzzi" assembled the block for me he is a member here
Old Jan 23, 2011 | 12:05 PM
o'malley_808's Avatar
Gonna look clean! I want to do the same to my bay eventually! Only thing that bothers me is that there is no way to rustproof the other side of the weld when it penetrates...Its all concealed within the frame so its inevitable that it will start to rust eventually. Any solution to this or is it even worth worrying over?
Old Jan 23, 2011 | 12:30 PM
dibi's Avatar
I rust proffed the back of the metal with weldable primer but I still left a small clean border of metal around the edges. When the car goes to paint my friend has a small wand that he can get into any access hole in which we can spray primer into those hard to reach places for further protection.
Old Jan 23, 2011 | 04:13 PM
siadam's Avatar
I've seen body shops use a hole saw on the underneath of a box style frame (like ours) where the entire frame is enclosed.
They have a product that looks like the expanding spray foam that has a 360 spinning nozzle, and you stick that in the whole and it sprays and coats the entire underneath of the frame/etc.
Old Jan 24, 2011 | 10:04 AM
The Gentch's Avatar
This may sound like a dumb question, but im fairly new to the S2000, but why are you remolding and shaving your engine bay? is it just cosmetic? Just wondering, but it looks nice bro, cant wait to see the finished result.
Old Jan 24, 2011 | 11:58 AM
TRBOKEV's Avatar
Yes, he's doing it for the cosmetic "bling" factor.
