My stage 2 setup s2k by inline pro
Old Feb 5, 2010 | 04:33 PM
IloveBooosssttt's Avatar
Default My stage 2 setup s2k by inline pro
I just wanted to give the guys at inline pro credit for the ridiculously amazing job they did with my S. I got my S like 8 months ago and ever since I've been wanting to boost it. I started off looking online at sum cheap turbo kits and researching the pro's and con's of these budget setups. Well as I started reading this forum and learning from other people's mistakes on cheaply turboing these cars is just a disaster waiting to happen. So I sat down and figured out what setup I wanted and called around to some shops in my state. WOW that was a mistake in its own they didn't even sound like they knew as much as I even do about the car. With this starting to bring me down I never thought I was gonna find a place to do the work that I trusted. Then I found inline pro I spoke to tom on the phone and he gave me an estimate on the setup I wanted, just from talking with him I felt a sense of ease because of the professionalism on the phone. I planned out the 6 hr journey to Springfield to drop it off. As soon as they figured out how I wanted it setup they took me for a tour of their shop, Just seeing all of the machinery amazed me and in the 45 mins I spoke to them they taught me so many things about my car that I had no clue of. I believe IP is the best tuner shop for S's and honda engines in general, their work was absolutely flawless on my car I was so happy. Not only was it a A+++ job they called me every step of the build and gave me an up date on my S. If you are thinking about FI your S and your not sure on a shop I fully recommend inline pro and you will be satisfied with the build/car.
With that done on to my setup
67/65 turbo
T4 manifold
1000 hp intercooler
3in testpipe
Greddy 70mm Ti-c single
IP bov
IP valve spring and retainers
IP 3mm head gasket
Stage 4 clutch
UL flywheel
Arp head studs
Aem ecu series 2
900cc injectors
And to set it off a set of 17in TSW jarama black rims
Well heres the link to sum pics of it =)
www.photobucket.com/home/IloveBooosssttt/index
Old Feb 5, 2010 | 04:42 PM
OOO ya I forgot let me no what you guys think on it =)
Old Feb 5, 2010 | 05:06 PM
rob!'s Avatar
is the turbo billet and what kinda power did you make with it?
Inlinepro does clean work.
Old Feb 5, 2010 | 05:14 PM
high 400 high boost. low boost like 350 sum.All on 91 pump.
Old Feb 5, 2010 | 05:32 PM
D1sclaimer's Avatar
What hot side A/R?
Old Feb 5, 2010 | 05:35 PM
D1sclaimer's Avatar
If you could, post up your dyno graph. I just received this same kit tonight from IP with a .81AR.
I noticed on my spec sheet that I received with it, it says the intercooler is rated for 1200hp and not 1000hp like it says on the website. I wonder which one is the typo.
Old Feb 5, 2010 | 09:13 PM
TRBOKEV's Avatar
Only high 400 high boost and 350 low?
That makes no sense with that setup...
Old Feb 5, 2010 | 09:34 PM
high boost is only 15 psi. Seems like alot on stock internals
Old Feb 5, 2010 | 09:42 PM
Spoolin's Avatar
You only made 400 whp on 15 psi and that big of a turbo? Mine made 465 whp at 14.5 psi on a dynojet with a turbo just smaller than a GT35. That 67 turbo youre running is near a GT40 in flow if its the newer billet turbo you have. Something doesnt seem right.
Old Feb 5, 2010 | 09:45 PM
NOOOO I said high 400s not 400 so ya sorry for the confusion.
