My Turbo S2000 Monster
Old Feb 22, 2007 | 03:08 AM
  #91
yiannakos's Avatar
great numbers
i wish you were here last night to deal with an evo that i missed about 4 cars with my 293whp s/c
that would be just a joke for you
Old Feb 22, 2007 | 03:31 AM
  #92
Ray K.'s Avatar
get a boost activated dump....cruising it is stock, wide open throttel it wil open up and not restrict you. You could even put a boost controller inline to the actuator and control exactly when the dump opens. Anyone try this yet?
ATP VES
Old Feb 22, 2007 | 10:23 AM
  #93
passmans2kny's Avatar
thats sick, have that open at like 5500 or 6000, gone
Old Feb 22, 2007 | 01:22 PM
  #94
antonio88x's Avatar
hey are u using the stock diff? did u have the cylinder walls sleeved (idk if you need too tho, just curous). im surprised that ur diff hasnt broken with all that power. awesome setup btw
Old Feb 22, 2007 | 06:39 PM
  #95
slimjim8201's Avatar
Yup, stock diff. I don't beat on it. I don't launch it. I don't hop it. I'm hoping my relatively mild steady state abuse won't lunch it
Old Feb 22, 2007 | 07:38 PM
  #96
antonio88x's Avatar
thats awesome. if you dont mind me asking, how much did everything come up to?
Old Feb 22, 2007 | 08:02 PM
  #97
One testicle.
Old Feb 22, 2007 | 08:16 PM
  #98
WLAURENT's Avatar
Originally Posted by slimjim8201,Feb 22 2007, 09:02 PM
One testicle.
Well that means you have a spare in case you need to get in the 500 club
Nice setup.
Old Feb 23, 2007 | 05:14 AM
  #99
Originally Posted by slimjim8201,Feb 19 2007, 10:12 AM
So what exactly causes the "fluttering" noise at low speeds in higher gears? Like gentle acceleration up a hill in 6th gear @ 40 mph leads to light fluttering or chirping noises from the BOV. I'm guessing that there is just enough air flowing through the turbine to cause the compressor to build very slight positive intake pressure (which is not needed). The intake pressure builds, and reaches a certain level at which the BOV vents, the intake pressure drops, the BOV shuts, the compressor again builds slight pressure and the process repeats itself. Thats my guess at least.
Can anyone clarify or elaborate on what is going on here. I think it's just the way that the BOV handles lower magnitude pressure releases.
Should make for a few interesting "WTF is that" comments from first time passengers.
Can anyone shed some light on these noises? If I cruise around in 4th gear, the noises do not occur. My guess is that it takes MUCH less throttle opening in lower gears to draw the same desired power/acceleration. In 5th gear or especially 6th, when I'm cruising at 50-60 mph and gently accelerate, lots of chirping occurs.
My take is that the additional throttle opening is having an interesting effect on the intake manifold vacuum/BOV operation. Basically, the BOV is getting confused whether or not to open or close? Thus building and releasing very slight pressure at a high rate? The compressor is spinning just fast enough to build pressure in the intake charge pipes, but the manifold is still under vacuum due to the low throttle application.
As the throttle opens more and more, the pressure in the intake manifold rises slightly, causing the BOV to either stay open or just not want to fully close. Or go into a repetetive loop or opening and closing quickly.
I have no idea if this is the sound or not. I'm almost positive it is NOT the wastegate, as that only opens at very high turbine manifold pressure (which cruising around will never cause).
Could it be something else? Something peculiar with the compressor?
Any insightful comments would be great!
Old Feb 23, 2007 | 06:10 AM
  #100
Guerillah's Avatar
Sounds like compressor surge to me.
Every turbo has a surge line, and when you go past that surge line which usually happens at low rpm/high load (5th-6th gear) it will make that noise, its essentially the turbo stalling itself. Watch out doing that cause its bad for the turbo.
