In need of 2mm headgasket
What are some good sources for a 2mm headgasket for stock AP1 motor? By stock I mean stock pistons/bore. I plan on turning up the boost a little
Thanks.
Thanks.
DU MA you in cali and you dont know where to get one, lol. You can get one at Cometic a 2mm thicker headgasket from them for 109, with shipping its 113 i think. i gave them a call the other day.
$110 for the gasket, around $5 for shipping. If youre using the gasket, I also recommend ARP headstuds for $150, otherwise youll be limited with the amount of boost you can run before the head starts lifting(16psi for me).
