need a base map for AEM EMS
Old May 23, 2011 | 10:21 AM
erikvanden's Avatar
Default need a base map for AEM EMS
Hello, I am upgrading my CT SC Kit. I have an AEM EMS, 11PSI pulley, and ID1000 injectors. I will probably be throwing the parts in this week but I need a base map for the EMS so i can drive to the tuner. can anyone help? I am a little new to engine management systems. I just need something to get to the tuner and maybe drive around town a couple days before. I wouldn't go over 4k RMP or 30% throttle. my only other option is to tow the car or drive their with the stock EMS and stock injectors then switch before the car gets on the dyno.
Old May 24, 2011 | 07:48 AM
jb34304's Avatar
Well DON'T drive it around. And either go straight to the tuner or on a flatbed to him/her...
Old May 24, 2011 | 08:40 AM
erikvanden's Avatar
well does anyone have a base map? A flat bed seems unnecessary. Maybe if it was a turbo setup but it isn't. all I really need is a tune for a stock s2k that compensates for the injectors. I can easily drive around without making any boost. hell I could even take the sc belt off.
Old May 24, 2011 | 09:47 AM
3en's Avatar
3en
Contact your tuner, he should be able to email you a base map that should be able to get you there.
Old May 24, 2011 | 08:01 PM
bruthaboost's Avatar
AEM gives you a decent base map. On stock injectors, it drives like stock. It's in their library; just stay out of boost. If you want to use your id injectors, use the injector wizard and the ems will adjust your duty cycle. It won't be perfect, but should be close. Your cold idle enrich may be off, but again, it'll get you to the tuner. If you have a wideband, you can clean it up some.
Old May 25, 2011 | 05:01 PM
erikvanden's Avatar
Where is the base map that AEM gives you? also i couldn't find the id1000s in the wizard.
I did talk to my tuner though and they said if i stopped in before that they should be able to make me one. i just have to drop of the ems for the day. Still it would be nice if i had another basemap incase something goes wrong with the tuner. I will check the library feature if i can find it
Old May 25, 2011 | 08:34 PM
Round 3's Avatar
There should be a supercharged ap1 map in the aem software. Use the wizard to select your map sensor and injectors.
rikhemi
Mar 16, 2014 06:15 PM
eSeM
Jul 6, 2009 02:55 PM
ShMooveS2k
Aug 24, 2007 11:42 AM
Lilbastrd
Aug 2, 2007 01:16 PM
ShMooveS2k
Jun 22, 2007 04:17 PM
