Need to bleed your coolant?
Old May 28, 2012 | 05:15 AM
o'malley_808's Avatar
Default Need to bleed your coolant?
Came across this tool and it makes bleeding the s2000 system much much easier! With this installed I can get the fluid level above both bleeders with the car on level ground.
No mess and works very well!
http://revlimiter.net/blog/2011/03/t...l-free-funnel/
Old May 28, 2012 | 06:01 AM
Redline S2K's Avatar
I got one of those. Pays for itself since I work at a Toyota dealer. Makes life alot easier.
Old May 28, 2012 | 07:06 AM
DFWs2k's Avatar
Is there a way to bleed/mostly bleed without running engine? Or how do they do it when breaking in new engine?
Sent using free Tapatalk - Android FTW
Old May 28, 2012 | 09:02 AM
Phill24's Avatar
i have 1 also....love that thing...full the system and walk away run the car till the fans come on
Old May 28, 2012 | 10:38 AM
wy2slow_z's Avatar
got mine at summit. makes things cleaner and easier
Old May 29, 2012 | 08:25 AM
s2klariat's Avatar
Thank you for this! Going to grab one this weekend.
Old May 29, 2012 | 09:00 AM
wait4vtec's Avatar
so to use this, your cooling system must be empty correct? like id have to completely refill all my coolant?
just wondering because i think i have some small air pockets and was wondering if id have to drain out and start over
Old May 29, 2012 | 09:05 AM
InductionPerformance's Avatar
Bleeding the cooling system properly is one thing I see customers either not do or do improperly on a weekly basis.
Old May 29, 2012 | 09:25 AM
TerminatioN's Avatar
Awesome. Will definitely pick one up. Thanks
Old May 29, 2012 | 09:39 AM
herecomesboost's Avatar
