Need Greddy Base Map CTSC
I am looking to see if anyone has a base map for an emanage that is CTSC on stock boost (5.5 psi).
I need a map to be able to get to the tuner.
Enthralled helped me out with his ultimate setup which I will try but just in case...
Thanks so much
Gus
Thanks so much
Gus
Originally Posted by Enthralled,Dec 1 2007, 05:15 PM
just use the map i sent you...it'll get you to your tuner. just don't boost.
btw the map i sent you is for a 8psi Vortech AP2. or did i send it to you
I decided to start with stock boost first....
can I use the ultimate map with the blue?
what settings in the map do I have to adjust to compensate since its used for a 8psi..?
thanks
I do have another map WLAURENT sent me. it was a bit lean at first(gave me a CEL)..so i adjusted the map a bit and it ran fine till i got to the tuner. I used this map for about 2 weeks.
PM me your email addy again and i'll send it to you after i get off work.
Originally Posted by revhi,Dec 1 2007, 06:35 PM
Did you change the FPR? If not you dont need a base map, just map clamp at 2.89v.
What do u mean by map clamping?
thats right.. you're the one with the Blue. I sent you a PM a while back just to show you what type of setting to enter.the Ultimate file will not work with the blue.
