NEED HELP! 2.4L stroker with gt35r and hypertune
Old Dec 2, 2007 | 08:51 PM
Elite Performance's Avatar
Default NEED HELP! 2.4L stroker with gt35r and hypertune
i recently finihsed my 2.4 lstroker set up pn my ap1 heres the problems
when i installed the aem slftware on my new toshiba laptop i plug the ecu to the laptop and aem tells me "failure to connect" i plug something into the same usb port and it works fine only does not work with the aem....
so i used an older computor with windows 98 and it worked fine....
so then i go threw the basic configurations on the aem and then i get to the ign calibration and it requires the car to be at idle so i go to start the car and it will not start..... i double cheked all my wiring all my connections everything.... all good all sensors good and everything is good i dont get it... car cranks fine starts fine and it dies after 2 secs.... i cheked all the vacuum and its all good....
now i am running 1000 cc precicion injectors will the car run just idle with these injectors and no injector driver (like the aem injector driver) or will the car not start at all without the injector driver (because i do have injector pulse)
im also running a return on the fuel setup any difference where with tuning or starting the car?
my fuel set up is as follows tank>filter>external pump>fuel rail>regulator>back to tank
any help or advice would be great and really really appreciated as this is driving me nuts!
Old Dec 2, 2007 | 10:29 PM
jei_s2k's Avatar
First make sure that your filter between the tank and pump is a low pressure filter. If it's a high pressure or fuel injection type filter, your pump won't be able to draw the fuel thru.
Second, if you have a connection issue, it may be a driver issue or you may need to pick the right serial Com port.
Thirdly, if you haven't already, you need to setup your injectors under SETUP.
Fourthly, take it to an experienced AEM Tuner
Old Dec 3, 2007 | 12:14 AM
s0rted's Avatar
Elite performance, when you start AEMpro, click on the 'home' icon on the menu bar. On the dashboard in the top right hand corner there's a parameter labeled 'sync'. Start the car car up and see what it does. It should be off then turn on and stay on after a few cranks of the engine.
Old Dec 3, 2007 | 05:41 AM
s0rted's Avatar
About the 1000cc injectors, if they are peak and hold injectors ( low resistance) then you'll run into problems if you don't use an injector driver or similar, since our cars come setup for saturated (high impedance) injectors.
Old Dec 3, 2007 | 08:04 AM
Asura's Avatar
You will burn out the injector drivers inside of the AEM ems box as you currently have the 1000cc injectors configured.
If you are using MS Vista, it is not stable with the AEM software.
Old Dec 3, 2007 | 08:37 AM
AirborneS2K's Avatar
oh the importance of having an AEM savvy person or tuner with you when you try to even fire up the car...
Old Dec 3, 2007 | 08:48 AM
PeanutButter's Avatar
Take the USB cable and launch it really really far away....
Buy a serial adapter and run it on your laptop, this is a guaranteed way to work
Old Dec 3, 2007 | 10:41 AM
thanks guys for all the advice gonna try it out today my injector driver comes today hopefully thats the problem.....
rikhemi
Mar 13, 2014 01:02 AM
stantaur
Forced Induction For Sale
Apr 5, 2013 08:09 PM
GDM S2K
May 15, 2007 11:09 AM
my01s2k
Apr 1, 2006 08:45 AM
Sub-Zero
Mar 6, 2005 07:45 AM
