Need Help
Old Feb 21, 2010 | 03:06 AM
RedLineS2k10's Avatar
Default Need Help
I was recently on the dyno and was running into issues around peak powerband. once i start hitting it on low boost (10psi) it starts misfiring all over the place. I couldnt get the car finished at the dyno this week because of some "ignition problem" around 5,500 rpm. basically just on WOT now the car will start to misfire. Ive talked to a few people but the problem is that from the build photos of this car and what is actually inside (valve springs) is somewhat different then was described. From what i can tell i am running BC Stage 3 Cams (BC00062) and stock springs (leftover paint markings on springs intake-yellow-exhaust-blue). So I dont know if im floating a valve, or having an ignition issue, or cam timing problems. Any suggestions would be a great help. Thanks guys!
If anybody wants to see the specs on the motor, I included some links below
Link 1
Link 2
Link 3
Link 4
icemans2k02
Feb 28, 2017 07:23 AM
riceball777
Apr 14, 2014 07:32 PM
lilgookiemonsta
18
Dec 11, 2008 08:27 AM
crank
Nov 17, 2008 08:40 PM
honda9krpm
17
Oct 29, 2003 01:37 AM
