Need help with installing my new sensors
Old May 6, 2011 | 02:34 PM
s2knoob89's Avatar
Default Need help with installing my new sensors
Ok, I need some help with what pins to use on the AEM series 2. I need to hook up a 150 psi oil pressure sensor and a oil temp. sensor. I am a NOOB at this and please don't tell me to search.
Oil temp. sensor Pinout:
One wire to sensor ground
One wire to sensor signal
Oil pressure sensor Pinout:
Red wire to +5v reference pin
Black wire to Sensor ground pin
Green/White wire into MAP signal pin
http://www.aemelectr...s%2030-6052.pdf
Old May 7, 2011 | 03:40 AM
AusS2000's Avatar
MAP signal? MAP usually stands for Manifold Absolute Pressure. It is the charge pressure in your inlet manifold.
The signal output of both those sensors should plug into two of the Spare 0-5 Channels (Pin A29, C6, C24 D8) I would guess.
Old May 7, 2011 | 03:50 AM
Rob@ReidyRacing's Avatar
I will be able to help with the oil pressure sensor as Rywire just made me up a harness with one. Hold tiught and I'll take a look for you when I work on the car later today. I know both my oil pressure and my inline wideband used the au plug on the ecu for these features. Im sure you already know that though.
Old Jun 2, 2011 | 09:13 AM
s2knoob89's Avatar
OK, so I got the oil pressure sensor hooked up using pins D6,D8 and D9. Now I am having problems with the temp. sensor. I used pin C6 (ADCR11) and A7 (sensor ground) but the sensor isn't showing the correct voltage. It starts out around 0.50 volts and then starts to go down as the oil is warming up. Maybe a bad sensor?
Sensor I bought: http://www.aemelectr...sensor-kit-1237
Temp. calibration table: http://www.aemelectr...s%2030-2012.pdf
Old Jun 2, 2011 | 11:05 AM
Blucky87's Avatar
D6 is not ADCR11
D6 is an output and C6 in an input
Old Jun 2, 2011 | 11:20 AM
s2knoob89's Avatar
Originally Posted by Blucky87
D6 is not ADCR11
Sorry, typo fixed.
s2kpotenxixe
Mar 23, 2014 12:30 PM
admans2k
Sep 5, 2013 12:24 PM
Sergei
May 16, 2012 03:22 PM
s2knoob89
May 6, 2011 02:29 PM
Boostaholic
Jun 4, 2007 09:28 AM
