Bringing in oil temp sensor into aem series 2
So i have a 2 wire generic temp sensor that ill use for oil temp.
I presume its 0-5v, but i have connected it to sensor ground and ADCR14 5v 1.5a pull up - so pins D8 and D9.
I added the channel in aem and scaled it from 0-150 c, but i can't seem to read anything from it? Am i on the right lines?
Thanks
Thanks
Thanks
Thanks
Yes sorry that's right but can anyone confirm correct wiring etc?
I have a generic temp sensor two wire, wired to d8 and d9
but it won't pick up anything the pin is adcr14, and sensor
ground and has a 100k pull 5v.
Have I wired it correctly?
It just sits at 0v, or have I got to map resistance against temp, not sure how to do it?
chrispayze
Aug 31, 2017 12:07 AM
