Need help with a major decision.
Some of you may be following my mis shift issues in the UTH section. Anyway, I recently had an engine issue where I lost all compression in cylinder #3 and the head is currently at the machine shop being repared. What the outcome will be eventually is still up in the air. I will be having the dealership install my 3mm cometic HG and ARP head studs per specs. Obviously when that is complete I will have another leakdown test to make sure the compression is alright.
Now to the quesiton. Would you still boost the car.
Its a major question because if the motor is to weakend from the mis shift I will end up selling it as 200whp or even 300whp isn't enough for my blood anymore. Any comments are welcome but I will seriously consider anyone who has had a similar issue and decision. Thanks in advance.
Its not like there is a giant hole in your block that some tech fixed with bondo, probably some valves needing replacement
Was the head damage the obvious cause of the loss of compression?
The reason I ask is that I also suffered a loss of compression resulting in plug fouling and misfiring. But a clean up and she would run again... for a while.
The problem was a cracked ring.
I would hate for you to do all this work and put it back together only for the problem to reoccur.
Originally Posted by afwfjustin,Apr 16 2007, 05:20 PM
Keep in mind, if you put the headgasket on you'll need management to be able to manage it. You wouldn't be able to sell a stock S with 9:1 compression
Silver_Bullet_S
May 9, 2018 06:42 PM
jyeung528
51
May 26, 2009 11:19 AM
