Need help, Turbo Problems!
I used to have problems like the ones that you are talking about... and I read a post from Chitah*** that talk about how he fixed hes problems.... and it actually WORKED... let me see if I can find it... what you have to do is Zero out the first two rows on the Add Inj Map... do this with a cold engine... after you do this, disconnect neg cable from battery for about 10 min and replace... start engine and let it idle for about 5 - 10 min so the ecu learns how to play with emanage.... take it for a easy spin and see how it works....
D.
D.
CIVICTOS2000 I remember reading chitah's old threads but that was before I had my set up up and running. I am going to try to find that old thread since my support tool should be here any day now..Thanks Spec_Ops2087
If someone comes across it could you post the link here or pm?
Does anybody know where I can get a tutorial on how to tune the emanage. Any advice on the software would be very helpfull.
Does anyone else have any suggestions on what could be wrong with the car?
I am certain that the erratic rpms is related to the jerky throttle as well. I dont get it, at a stand still free rev everything is fine untill I get to 2k and then the rpms jump to 3k and then back down. It just continues to do this.
Thanks
Martin
If someone comes across it could you post the link here or pm?Does anybody know where I can get a tutorial on how to tune the emanage. Any advice on the software would be very helpfull.
Thanks
Martin
