need info on e85
Race gas is pretty expensive out here. More and more gas stations are getting e-85. My jeep can run it, but regular is still cheaper so I haven't used any yet. I understand how everything would need to be setup in order to use e-85 on the S. How would e-85 compare to race gas? Say 110 oct. Would I be able to get close if not the same numbers?
You would get the same numbers it is like cheap race gas. The only thing that is different is that it burns more fuel. E85 is somewhere around 106oct to 108oct. I run this on my S2000 depending on how much power you are looking for will determine your fuel set up. I have taken my car to 500hp on Injector Dynamics 1000cc's and a single walbro but is close to max on this setup. But you will make same numbers..
Originally Posted by PsykotiK,Jun 12 2009, 02:59 PM
why not run dual pumps rails and injectors instead of doing 1600cc injectors.. theres alot of problems involved with running that big of an injector.. bad spray patterns and all..
Thanks GDM, but that doesn't really help or answer any questions. If I did do this I'd use twin pumps and 4 1000's I just do not know if it's worth the money vs race gas. It seems like I'd get more out of race gas as well... No?
Originally Posted by sbrodacz,Jun 12 2009, 09:33 AM
So e-85 isn't as good as 110 since it's 106-108. It seems similar to running 93 oct with meth. If I was to convert I'd need twin pumps and 8 1000's.
