Need opinion on what to do with charge pipe.
So I have the ptuning kits charge pipe off of the throttle body down. Its a one piece that goes down. I had it orignally modded to fit a bov on it, but the dummy who did it left a pin size hole in it and did some stupid ass welding. I have to get that piece cut out now after I got it already powder coated, weld in a replacement piece, then get a new BOV flange welded in the correct location since, then re powder. Is this all worth it. InlinePro quoted me 150 just for labor. I think thats a lot. Its starting to get aggrevating.
I was thinking about just cutting off the bad piece, get a silicone coupler long enough to to match the part I cut out and attach it together. Wont look as nice but its in front of the radiator so it wont look that bad I guess. Then get the bov welded in the correct location and just powdercoat that portion of it.
No I wasn't going to have it bead rolled. I am just going to drop it off at another shop today and have him finishing the pipping. I know people get pipes that bead rolled to prevent it from coming loose, but thats in extreme cases where you pushing a lot of PSI. I haven't had all my pipes bead rolled when I made my pipes.
I have one pipe on my set up not bead rolled and it held 30 psi for a few thousand miles with out a problem, not saying its the way to go but it can be done, also I was using t bolts and jammed the coupler a good 2 and a half inches over the pipe
pedroelbee
May 25, 2012 04:51 AM
