Need some advice on what Precision turbo to get...
My goal for now is btwn 350-400 WHP on 8PSI, would like closer to 450/500 when I do a 3mm Headgasket down the road. But I dont want to be waiting on the turbo to spool right now either.
I have a few choices, they are all similarly priced, keep in mind HP is rated at the crank, not wheels.
SC5031 - 450 HP
http://www.extremepsi.com/store/customer/p...&cat=508&page=1
SC3431 - 545 HP
SC6076 - 610 HP
HP5757 - 540 HP
http://www.extremepsi.com/store/customer/p...cat=1654&page=1
My set up is
rev hard log manifold
rev hard 2.5" DP
63mm Test ipe
63mm J's exhaust single
IC piping is 2.25"
SC5031 - 450 HP
SC3431 - 545 HP
SC6076 - 610 HP
HP5757 - 540 HP
My set up is
rev hard 2.5" DP
63mm Test ipe
IC piping is 2.25"
SC5031 - 450 HP
SC3431 - 545 HP
SC6076 - 610 HP
HP5757 - 540 HP
My set up is
rev hard 2.5" DP
63mm Test ipe
IC piping is 2.25"
SC5031 - 450 HP
SC3431 - 545 HP
SC6076 - 610 HP
HP5757 - 540 HP
My set up is
rev hard 2.5" DP
63mm Test ipe
IC piping is 2.25"
But if you want reduced lag/better transient response, I'd shoot for ball bearing.
SC5031 - 450 HP
SC3431 - 545 HP
SC6076 - 610 HP
HP5757 - 540 HP
My set up is
rev hard 2.5" DP
63mm Test ipe
IC piping is 2.25"
SC5031 - 450 HP
SC3431 - 545 HP
SC6076 - 610 HP
HP5757 - 540 HP
My set up is
rev hard 2.5" DP
63mm Test ipe
IC piping is 2.25"
Originally Posted by spdracerut,Jul 22 2009, 02:39 PM
Why not check out the GT3076? It's proven to make the numbers you want. Granted, you said you wanted to stick to journal bearing, which I assume is due to costs.
I think the SC3431 is good for what Im shooting for.. just want a few other opinions
Originally Posted by AndyFloyd,Jul 22 2009, 02:51 PM
Precision 5857SP Journal bearing. 900.00. 550whp capable. Spoolup as good as if nto better than a GT3076R.
For your goal your gonna need a pretty large turbo to get 350hp at 8psi. A goal of 10psi is more like it and then you will need a large turbo like a gt35. You can make your HP goal but your set up is a log. I made 330 with a gt 3076 at 9.5 psi.
