Need some advice on what Precision turbo to get...
Old Jul 22, 2009 | 10:10 PM
  #21
combats2000's Avatar
precision turbo 6031E .63 A/R 4 bolt outlet
http://www.extremepsi.com/store/customer/p...&cat=508&page=1
THATS THE one i bought.. i got it for 600 .. and can get more pm me
Old Jul 23, 2009 | 05:23 AM
  #22
Momentum's Avatar
Go with a Garret I'm one of the few that has actually tested the two. The used a 35R and 6262 both had the same AR exhaust housing. The test was on the same car, same boost, same day (about 2 hours to swap the turbo) the precision lost out in every manner. I had an EGT, EMAP, MAP, and an air temp sensor on the turbo outlet. I can honestly say that the precision was not better on any account including power AND spool. I am not biased towards Garret and at the time of the test was hoping the precision would be better or the same due to the cost difference.
It's worth noting though that this was at the 400hp level not maxed out for either turbo...
Don't fall for the hype a lot of shops are pushing these turbos (some with dishonest power numbers). We hoped to push them as well, they are much cheaper making kits easier to sell and they have a higher profit margin but in the end quality and performance is more important.
Old Jul 23, 2009 | 06:10 AM
  #23
Envied's Avatar
Are you running an inline or revhard manifold? If so, did you have to notch the frame to fit that?
Old Jul 23, 2009 | 06:20 AM
  #24
Revenge's Avatar
I hope that turbo works out for you I am really intrested in the results. I just know that the 5965 turbo most people run can make just under 500hp on a inline set up which slightly better than your set up. But you should see better spool and great results regardless. I guess it also depends on what dyno you use.
Old Jul 23, 2009 | 12:28 PM
  #25
yes i had to cut the frame...rev hard mani
Old Jul 23, 2009 | 12:47 PM
  #26
Deception's Avatar
you think I will have to cut the frame with the 5857? The turbonetics I had fit with a little room to spare
Old Jul 23, 2009 | 04:05 PM
  #27
Soul Coughing's Avatar
very interesting. do you have any graphs to compare the differences?
Old Jul 23, 2009 | 07:55 PM
  #28
Deception's Avatar
another question.. could i use the compressor cover from my turbonetics on the 5857? I know that fits in the tight space.
Ill notch the frame if needs be, but an easy out would be better
Old Aug 2, 2009 | 04:48 PM
  #29
Revenge's Avatar
any updates on how your set up is coming along
Trackforged
288
Aug 19, 2014 01:23 PM
CRXsir29
NYC Metro Stock Exchange
Jul 16, 2011 02:31 PM
MANOS_BLUE
May 23, 2009 06:36 AM
p0pe
Jul 14, 2004 01:28 AM
