Need some help !
Old Jul 2, 2012 | 05:21 AM
jpetch05's Avatar
Default Need some help !
Hey guys. I know that "relatively" the safe number on pump is about 14psi.
Now I had a gt3076r on 14 and made 425
But switching to my Borg Warner s300sx fmw is gonna make more power on 14 obviously because it's moving more air.
So now what ? Is 14 still the safe number ? Or should I stop around 12 ?
I plan to go e85 but I'm Gonna need a 93 tune.
Old Jul 2, 2012 | 06:14 AM
cuci591's Avatar
Ive ran 21 pounds of boost on my car for 3 years now with no issues. I wouldnt say theres a certain amount of boost you should run to be safe. Its more along the lines of how good your tune is, Its all in the tune.
Old Jul 2, 2012 | 06:18 AM
jpetch05's Avatar
Even on 93 ? I'm a Stock motor. Besides valve train. Still stock headbolts.
Then why is 14lbs the safe number ?
Old Jul 2, 2012 | 06:25 AM
spectacle's Avatar
Because its been copy and pasted the most on this forum.
Old Jul 2, 2012 | 06:26 AM
jpetch05's Avatar
Hahahahaha hahahahaha. Hahahahahahaha.
It doesn't detonate when you get above that ?
jpetch05's Avatar
I figure that's why go e85 due to octane
Old Jul 2, 2012 | 07:08 AM
camuman's Avatar
your tuner will tell you when to stop. ive noticed 14psi is around the number most stop at. you will make good power on pump with that turbo and that mani, only thing i would wonder about is how that adapter will effect the turbos performance.
otherwise, i think you are fine. dont focus on the psi or the power. let tuner tune to his comfort level. also the type of dyno effects the numbers you will see.
Old Jul 2, 2012 | 07:10 AM
jpetch05's Avatar
Sounds good ^^ thanks man.
And tbh. I don't think it will at all. It's less then a half inch thick. T3 gasket one one side and t4 gasket to the other side. It looks like a perfect fit when it was on.
Old Jul 3, 2012 | 02:57 AM
timg's Avatar
I've done 16 psi on 91 octane, but that was a built motor with lower compression. Like they said above, it all depends on the tune.
One think to look out for, the S300SX FMW has a 3" compressor outlet versus 2" on the GT3076R.
Tim
Old Jul 3, 2012 | 07:42 AM
jpetch05's Avatar
Tim
It has a 2.5
volcomboy390
Oct 2, 2013 11:36 PM
SpoolinU
Sep 24, 2009 06:49 PM
josh7owens
Sep 21, 2009 10:18 AM
reds2k2000
Mar 24, 2009 07:18 PM
adam_gipson
Jul 5, 2005 12:35 PM
