NEED TUNING HELP
Old May 7, 2005 | 08:13 AM
SpoonS's Avatar
Default NEED TUNING HELP
I HAVE 1000CC injectors and on at about 8000rpm the car is leaning out,now has anybody experienced this and what can i do any help would be greatly appreciated,and im only at 7lbs now i will have high boost set at 15lbs ......
Old May 7, 2005 | 08:24 AM
s4000k racing's Avatar
wat you have done to it? you need. to add more fuel at 8k and up check your plugs too
Old May 7, 2005 | 09:14 AM
SpoonS's Avatar
INLINEPRO kit ,aem ems, head gasket,255lph fuel pump,1000cc injectors
Old May 7, 2005 | 09:19 AM
S2000_Europe's Avatar
PM fprrea, hi is running +14 psi and uses smallers injectors than you, i think he got 750 cc.
It is very strange that you are lean with only 7 lbs with 1000cc injectors
Old May 7, 2005 | 09:23 AM
SpoonS's Avatar
I KNOW IMAGINE WHEN I GO HIGH BOOST!!!!!!!!
Old May 7, 2005 | 07:32 PM
SpoonS's Avatar
fixed!!!!!!! installed resistor box not leaning out anymore thanks guys for your help
Old May 7, 2005 | 07:59 PM
kane.s2k's Avatar
Ahh...beat me to it.
BTW, those 1000cc's are larger than you'd ever need with that setup. Coulda saved yourself some idle issues with smaller injectors. 750cc's can do 500whp no problem with the right fuel pressure.
Old May 9, 2005 | 03:32 AM
SpoonS's Avatar
yes i know 1000cc is alot but whatever im not going to change them now hopefully i should get my car today!! i might tune to get some numbers on 7lbs..then some numbers on 15lbs in 2 weeks!
Old May 9, 2005 | 05:08 AM
chris_barry's Avatar
**** Doh, missed the post about the resistor pack****
**** I'll leave the info here for reference ****
If your fuel pressure is OK and there are no sensor or electrical problem your problem is most likely you are running mega rich.
Sounds wierd, but if you run a engine really rich the car will start to miss-fire, or in extreme cases it stops firing all together. The air fuel meters look at the amount of oxygen in the exhaust system. If your engine misfires, or the spark gets blown out the meter will read lean, even though the engine is pumping fuel out the exhaust pipe. If its not burning the fuel the sensor sees the unburnt oxygen, not the unburnt fuel.
Try leaning out your fuel values just above where the problem starts and come up to the load cells very gradually so you dont slam into any rich parts of the tables.
Good luck.
Chris.
Old May 9, 2005 | 06:58 AM
S2000RAT's Avatar
What do you need a resistor pack for?
