Negative effects of doing this?
Old Dec 28, 2012 | 11:39 AM
CoolGuy094's Avatar
Default Negative effects of doing this?
What are the negative effects of putting one of these breather filters directly onto the front crankcase vents that is normally ran to the intake tube? This would be opposed to leaving it attached or running it to a vented oil catch can (wouldn't this basically be the same?).
Old Dec 28, 2012 | 02:26 PM
wy2slow_z's Avatar
nothing. both are venting to atmosphere through the little filter. most ppl run at least 2 -10 hoses to a catch can and or that filter.
Old Dec 28, 2012 | 06:30 PM
s2knoob89's Avatar
Zero negative effects. A lot of us run like this.
Old Dec 28, 2012 | 07:14 PM
p0staboy's Avatar
Not sure about the emission laws in the states but that's a big ticket in ontario,canada
Old Dec 28, 2012 | 08:04 PM
CoolGuy094's Avatar
I understand the emissions standards and such regarding it... I just wanted to make sure I wasn't unknowingly doing something harmful. Will the filter become saturated with oil that would have otherwise been sucked into the intake and burned off? Will I see any oil collecting or dripping from the filter? Will this cause additional sludge or general goopyness in my crankcase?
Old Dec 28, 2012 | 08:07 PM
starrman's Avatar
I have had that little filter on my car for at least a year...I just change it when it no longer looks white...no issues that I am aware of.
Old Dec 29, 2012 | 07:05 AM
Corey Maurer's Avatar
Are you talking welding bungs to the front of the valve cover and just filtering those? If so.. Don't
Old Dec 29, 2012 | 06:35 PM
CoolGuy094's Avatar
No, I was not planning on doing that. I may move to a catch can setup off my PCV sometime later, but for now all I was wanting to do is NOT run the front vent hose to my intake tube. I picked up one of those little filters from Autozone and pushed it on. Good to go. Thanks for the help all. Here is a picture of my new setup, mini filter and all.
Old Dec 30, 2012 | 08:54 AM
wrecked's Avatar
my opinion is, over time, enough oil vapor will come out of there to start making your engine bay sticky/messy so it's better to just run it to a vented catch can (filled with steel wool to further catch the oil vapor). Also, I would run a line from the pcv to the can as well and cap off the nipple on the intake. It's how I've ran it on my car with no issues for over a year now.
Old Dec 30, 2012 | 10:57 AM
CoolGuy094's Avatar
I agree and do plan on running exactly that in the near future.
